speaker harness question
if i buy aftermarket speakers for my car can i plug them into the same place as the old speakers or do i need one of these
http://www.circuitcity.com/ssm...#tabs
will they sound like crap if i plug them into the factory wires
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
The speakers are only going to sound as good as the signal they are reciving. The stock speaker wires are good up to 40 watts. But I seen systems that used 50 rms watts thru factory wires that sounded great. And you would not even tell the diffrence. But thats were I draw my line and replace to bigger speaker wire. The adapters will be okay.
Ditto the above^^^
Your HU is 22W per ch into 4 ohms...
Audio
Continuous power output is 22 W per channel minimum
into 4 ohms, both channels driven 50 to 15 000 Hz with
no more than 5% THD.
Maximum power output ....... 50 W × 4
Load impedance ...................... 4 W (4 W to 8 W allowable) W should be ohms
Preout max output level/output impedance
.................................................. ... 2.2 V/1 kW
94
Audio
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cityslicker1606 »</TD></TR><TR><TD CLASS="quote">to get the most out of these speakers will i need a small amp.</TD></TR></TABLE>Yes.
94
94
all420
Audio / Security / Video
May 30, 2003 04:30 PM
94
