What kind of power can I get from SOHC turbo?
Old Sep 14, 2007 | 12:32 PM
i-VTEC_do_you's Avatar
Default What kind of power can I get from SOHC turbo?
I just swapped a SOHC ZC in my 99 EK and converted it all OBD2 to work with my engine harness. Its fun but not fast so I got myself a turbo kit from a buddy
HX manifold
HX to T3 adapter plate
2 Garrett turbos from 300ZX
Audi intercoller
FMU
Walbro fuel pump
2000 Prelude injectors
What kind of real numbers can I make with this? and what kind of boost do these kinds of turbos put out?
Old Sep 14, 2007 | 12:34 PM
quicksilver1689's Avatar
i ♥ snails
200whp~
I thought the 300zx had t25's or t28's?
Old Sep 14, 2007 | 12:38 PM
Default Re: (quicksilver1689)
they do the adapter plate doesn't bolt up the the guy said I need to slot the turbos holes and then use washers
200 for real??
Old Sep 14, 2007 | 12:45 PM
i ♥ snails
yeah tuning is going to make or break this setup. Suggest you invest in a obd2-1 harness adapter, get a p28 chip it, at least get a basemap made.
Old Sep 14, 2007 | 12:52 PM
what about charge piping, I know I can't go to big since the turbo is on the small side? and how much boost does it put out in stock form?
Old Sep 14, 2007 | 12:56 PM
i ♥ snails
depends on what the internal gate is set at i would guess 5psi-9psi. Read the FAQ section under forced induction and educate yourself!
APEXI Si
Jul 15, 2011 11:38 AM
OneSickJDMBB6
Jun 15, 2005 08:28 AM
krazeemidget
Feb 20, 2004 11:36 PM
Spade
71
Oct 8, 2003 02:59 AM
