Adjustable gears on stock cams?
Old Jun 16, 2002 | 10:06 PM
B19CivicHB's Avatar
Default Adjustable gears on stock cams?
Is it worth it? Ill be running 12.5:1 CR so i want maximun tunability. As of now ill have a VAFC, FPR, 310cc injectors, gsr fuel pump, mebbe the gears, all in a JDM GSR engine. Je pistons 20 over (1.9L), eagle rods, stock head, balanced, micropolished crank etc etc. Any other suggestions for tuning? I really dont want my engine blowing cause of detonation...
Thanks for any help,
-Nick-
Old Jun 17, 2002 | 08:15 AM
Spade's Avatar
Default Re: Adjustable gears on stock cams? (B19CivicHB)
Yes, the only thing is you will be adjusting where your power is......you will take away from low and put it high or vise versa........
TegLK
Engine Machining & Assembly
Mar 7, 2018 07:30 PM
mikeakap
10
Feb 23, 2012 07:14 AM
classdork987654
Jan 31, 2010 09:13 AM
boosh
Jan 4, 2008 01:32 PM
