adjust the clutch pedal
Old Sep 14, 2007 | 06:03 AM
93hatchattack's Avatar
Default adjust the clutch pedal
i need to adjust the clutch padal in the 93 civic dx i got a b16a and i bleed the slave cyl and it still catches all the way at the top. somone told me that there are 2 bolts that i can tighten on the pedal and it will get tighter. help me
Old Sep 14, 2007 | 06:38 AM
pdiggitydogg's Avatar
searching would have told you...
At the top of the clutch pedal there is a lock nut, undo it and spin the clutch rod until the pedal engages at a different spot.
A little goes a long way and you will screw it up a few times before you get it right
Stonage07
Mar 6, 2017 11:48 AM
Kyle244R948
Nov 26, 2008 01:25 AM
redman223
Jul 13, 2007 07:19 PM
jdmcivicferio
Nov 12, 2003 06:02 AM
MrSmith
Sep 28, 2001 08:30 PM
