ls swap problems
Old Sep 13, 2007 | 05:07 PM
hatchback freek's Avatar
Default ls swap problems
i have a jdmb18b motor, it has stage 1 crower cams and buddy club cam gears, i can start my car it will run but after a wile it will turn off, and while its running every time i hit the gas, it stalls. i guesing its the timing, i tried every thing (not everything) and nothing seems to work, what could be the problem? can some one tell me how to time them?
Old Sep 13, 2007 | 05:22 PM
Ron454321's Avatar
Get a timing light, its easy to do just make sure you jump the service connector. Or you can take it somewhere and have it done, can't be too expensive. If you need a write-up just search it up.
Old Sep 14, 2007 | 02:41 AM
Default Re: (Ron454321)
how about my cams, and my check engine light is on, and it stall when i hit the gas
Old Sep 14, 2007 | 12:34 PM
Ron454321's Avatar
Pull the code, there is a sticky on the main page for the 92-00 forum. Really easy, just need to jump a connector with some wire or paper clip and look at the gauge cluster.
Old Sep 14, 2007 | 06:01 PM
ok
Old Sep 16, 2007 | 09:08 AM
Default Re: ls swap problems (hatchback freek)
its pissing me off, nothing is working, evey thing is hooked up and yet noting works, timeing is on the stock place and still no results, some one please help me!
Old Sep 16, 2007 | 09:27 AM
93 EG's Avatar
what code are you throwing?
Old Sep 16, 2007 | 09:47 AM
SoCal B18b 4dr's Avatar
Default Re: ls swap problems (93 EG)
sounds to me that u have the firing wrong, maybe just 2 plug wires mixed up.... but with out what code ur throwing or more info, i dont think anyone can help u, what ur describing could be a lot of things.
Old Sep 16, 2007 | 05:48 PM
Default Re: ls swap problems (SoCal B18b 4dr)
it throws 41, i just got it running and it only revs up to 4 grand and sounds like its shitting rev limmiter, but when i spray starter fluid it will rev up highter, what could it be?
Old Sep 16, 2007 | 05:53 PM
geebs's Avatar
you swapped the TPS and the MAP connectors.. change them and it should idle/run/rev normally..
Modified by geebs at 9:04 PM 9/17/2007
Old Sep 16, 2007 | 05:54 PM
pdiggitydogg's Avatar
Default Re: ls swap problems (geebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geebs &raquo;</TD></TR><TR><TD CLASS="quote">you swapped the TPS and the MAP connectors.. change them and it should idle/run/rev normally..</TD></TR></TABLE>
sounds like it to me too
Old Sep 16, 2007 | 06:01 PM
Ex-Eg-Driver's Avatar
yea those plugs look identical. Try switchn those
Old Sep 17, 2007 | 04:02 PM
Default Re: (JayKayNidas)
41 is heated oxgen sensor, but i will swap the connertors any way
Modified by hatchback freek at 5:13 PM 9/17/2007
Old Sep 18, 2007 | 03:00 AM
Default Re: (hatchback freek)
no results, i think its a fuel injectors or pump problem
nogutsnoglory77
Jun 28, 2009 09:49 AM
DuVaL rAcEr
Jan 27, 2007 06:23 AM
JCCOOL43
Nov 7, 2006 05:32 PM
Reego.
Apr 6, 2006 08:04 PM
