Crank Angle Sensor with problems
Old Sep 13, 2007 | 03:02 PM
fracas's Avatar
Default Crank Angle Sensor with problems
I just bought a JDM B18b last monday. I put the motor in the car. Started hooking up the motor harness and noticed the JDM motor doesnt have a Crank Angle Sensor. I looked at the head to double check the year. And it has 1996 stamped on the head. I have a 97 civic running a OBD1 P75.
What i want to know is this. Will my P75 look for the Crank sensor Or do I need to get a OBD1 Ls Dizzy and wire the sensor?
Old Sep 13, 2007 | 03:04 PM
fracas's Avatar
Default Re: Crank Angle Sensor with problems (fracas)
Old Sep 13, 2007 | 03:25 PM
njracer's Avatar
It will look for it. Just do the ckf bypass trick. Just do a search, I'm pretty someone has done it here before.
Old Sep 13, 2007 | 03:38 PM
USDMCIVICHATCH's Avatar
Default Re: Crank Angle Sensor with problems (njracer)
um... no....obd1 p75 will NOT look for it
Old Sep 13, 2007 | 05:17 PM
fracas's Avatar
So is this a Yes or No?
Old Sep 14, 2007 | 03:22 PM
Default Re: (fracas)
you will be fine with a 94-95 p75,96 and newer obd2 USDM ecu's are the only ecus that read that sensor, your motor is jdm so it doesn't have it at all
Old Sep 15, 2007 | 07:56 AM
njracer's Avatar
Usdmcivic is right, did'nt see the obd1p75.
nels00n
19
Aug 16, 2010 08:04 AM
andyvaj
Sep 14, 2007 09:19 AM
Spence
10
Apr 24, 2006 09:37 PM
