'93 Civic 1.6L rough at idle and low revs
Old Sep 13, 2007 | 01:33 PM
regal55's Avatar
Default '93 Civic 1.6L rough at idle and low revs
Lacking power. Idles oscillates up and down almost stalls but not quite. Driving it feels like it is stuck in too high a gear until it gets above 4000 rpm. Very sluggish, low power, high gas milage. No smoke out the tail-pipe. Compression on all cylinders 140 psi.
Almost like missing a cylinder. Changed plugs - no help. Plug wires look good.
No engine light.
Where should I start ?
Old Sep 13, 2007 | 01:35 PM
crazyguy's Avatar
Default Re: '93 Civic 1.6L rough at idle and low revs (regal55)
check the spark plugs firing order...and check your ground wires...battery..tranny and valve color
Old Sep 13, 2007 | 01:45 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by regal55 &raquo;</TD></TR><TR><TD CLASS="quote">Lacking power. Idles oscillates up and down almost stalls but not quite. Driving it feels like it is stuck in too high a gear until it gets above 4000 rpm. Very sluggish, low power, high gas milage. No smoke out the tail-pipe. Compression on all cylinders 140 psi.
No engine light.
Where should I start ?</TD></TR></TABLE>
almost sounds like a bad map sensor, or o2 sensor. are you sure you don't have a CEL?
follow these steps on the link:
https://honda-tech.com/zerothread/1901557
some time the CEL will come on for a quick second, fast enough to miss if you blink. but lucky for us the ecu doesn't forget nothing.
also, try replacing the pcv valve. they get clogged from time to time and can cause iraddic idles. not so much about being sliggish though, but doesn't hurt.
they run about $3 at the parts store.
Old Sep 13, 2007 | 02:26 PM
regal55's Avatar
When I tried to pull an engine code the CEL just stays on - no flashing. So there are no engine codes.
Modified by regal55 at 4:14 PM 9/13/2007
Old Sep 13, 2007 | 04:21 PM
regal55's Avatar
Also the idle is very low on average (below 500)
I am leaning toward the ignition. 120k mi, only thing I have ever replaced was the rotor at 80k. Probably due for a coil and ICU ?
Old Sep 13, 2007 | 04:31 PM
instrument's Avatar
this seems to be a common issue, with no common source.
i researched this a while ago, most people start with a basic tune-up, if that doesnt work you can move on to your ignitor/distributor.
my issue ended up being with my injectors, i ended up taking them out and cleaning em during my troubleshooting, and that ended up fixing it.
Old Jul 21, 2012 | 09:59 AM
TeGgYBwOi201's Avatar
Did u ever figure out the problem?im having this problem now
Old Jul 21, 2012 | 10:30 AM
Former User's Avatar
This is a very old thread. You will benefit by making your own thread. When you do, provide car and problem details.
95_DB7
Aug 31, 2012 09:56 PM
kid_02131
Dec 4, 2010 05:15 PM
spitfiremk2497
Oct 3, 2008 10:56 AM
cilvia
11
Apr 2, 2008 06:00 PM
Takumi Fujiwara
Apr 22, 2005 06:49 PM
