I can't seperate 91 SI engine and trans.
Old Jun 16, 2002 | 07:38 PM
DETROITREX's Avatar
Default I can't seperate 91 SI engine and trans.
How do you do this? Is there some trick to this? I just cant figure how to do it? I took out all the bolts, crow bar, grabbing the trans and shaking. AUGGH!!
Old Jun 16, 2002 | 10:10 PM
B19CivicHB's Avatar
Default Re: I can't seperate 91 SI engine and trans. (DETROITREX)
did you take the starter out?? One of the starter bolts goes thru the tranny casing into the block... if you've taken ALL the bolts out... keep shaking and shaking and shaking...
HTH,
-Nick-
Old Jun 16, 2002 | 10:48 PM
matt_sb2000's Avatar
Default Re: I can't seperate 91 SI engine and trans. (B19CivicHB)
HTH,
-Nick-
That would be the obvious solution, check all of the bolts. He does live in Detroit, and they salt the roads there.... Do you think that it is possable that there is rust holding the input shaft to the clutch disk? Or maybe the dowel pins are corroded? I have never worked on a car that is from back east, so I really don't know.
Matt
Old Jun 17, 2002 | 04:14 AM
Mista Bone's Avatar
D Tranny Guru
motorcityrex, I sent you a PM, do not spend the number.
Old Jun 17, 2002 | 12:09 PM
d-wreck's Avatar
Default Re: I can't seperate 91 SI engine and trans. (Mista Bone)
put down the crowbar for one. dont break any casings.
pull the lower starter bolt, that gets everyone.
then try to disengage the clutch and it should pop apart as easy as that. if not its got some bolts.
derek
dont break anything its expensive
Old Jun 18, 2002 | 01:45 PM
DETROITREX's Avatar
Yeah, it was the starter bolt. Took that out and it came right off. Thanx. Mista bone what is a "PM" that you said you sent me. Hey where do you live?
Old Jun 19, 2002 | 05:37 AM
Mista Bone's Avatar
D Tranny Guru
PM = Private Message. The phone number that was sent was of a buddy in Detroit that plays with Hondas.
Unleaded Racing Technologies.
Old Jun 21, 2002 | 04:28 AM
virginia_dude's Avatar
Dont forget there is a bolt above the drivers side axel going through the block and threading into the Transmission instead of vica versa.
Ekevans08
Dec 22, 2012 09:47 AM
slowLSTek
Transmission & Drivetrain
Apr 13, 2011 10:44 AM
EJ8chu
Sep 15, 2006 11:49 PM
ransack
Oct 3, 2002 11:58 PM
