I can't seperate 91 SI engine and trans.
How do you do this? Is there some trick to this? I just cant figure how to do it? I took out all the bolts, crow bar, grabbing the trans and shaking. AUGGH!!
did you take the starter out?? One of the starter bolts goes thru the tranny casing into the block... if you've taken ALL the bolts out... keep shaking and shaking and shaking...
HTH,
-Nick-
HTH,
-Nick-
HTH,
-Nick-
HTH,
-Nick-
Matt
put down the crowbar for one. dont break any casings.
pull the lower starter bolt, that gets everyone.
then try to disengage the clutch and it should pop apart as easy as that. if not its got some bolts.
derek
dont break anything its expensive
derek
Yeah, it was the starter bolt. Took that out and it came right off. Thanx. Mista bone what is a "PM" that you said you sent me. Hey where do you live?
PM = Private Message. The phone number that was sent was of a buddy in Detroit that plays with Hondas.
Unleaded Racing Technologies.
Dont forget there is a bolt above the drivers side axel going through the block and threading into the Transmission instead of vica versa.
Ekevans08
Dec 22, 2012 09:47 AM
