Spark Plug Orientation?
Old Sep 12, 2007 | 09:01 PM
all-mtr-teg's Avatar
Default Spark Plug Orientation?
I remember reading a thread about how the orientation your spark plugs are facing can make a bit more power. Does anyone have the link or can anyone shed some light on this. I believe I remember rocket breaking down some knowlegde on this issue, i just don't remember if they should face intake or exhaust side.
Old Sep 12, 2007 | 11:25 PM
Rocket's Avatar
Default Re: Spark Plug Orientation? (all-mtr-teg)
The ground strap should point towards the pulley or flywheel.
Old Sep 13, 2007 | 12:45 AM
DSRacing's Avatar
haha anyone see that new spark plug the pulsstar spark plug i seen it on tv they say a stock spark plug is only like 50w but the pulstar is a 1,000,000w haha for $25 a plug it better be i just wanna see some try it to see if it works cuz i dont wanna be the test dummy and try it first
Old Sep 13, 2007 | 02:59 AM
jdmDAsix's Avatar
Default Re: (DSRacing)
mark the side on which the "open end" of the spark plug faces. Proceed to install them as you normally would. use your ratchet to tighten the plug until the open end of the plug, faces the intake side of your cylinder head.
Old Sep 13, 2007 | 03:49 AM
Pippen_001's Avatar
How much power are we talking about here? I personally think it might help against a too lean miss fire but i doubt it would give you or prevent you from losing power once the bang started.
Old Sep 13, 2007 | 08:48 AM
thesmogman's Avatar
Default Re: (jdmDAsix)
This is the correct one. It is called indexing. The open side toward the intake.
Maybe one hp.
Old Sep 13, 2007 | 09:15 AM
Default Re: Spark Plug Orientation? (Master of the Universe)
thank you sir
Old Sep 13, 2007 | 11:53 AM
satitus's Avatar
From the NGK website:
4. Indexing
This is for racers only !!
Indexing refers to a process whereby auxiliary washers of varying thickness are placed under the spark plug's shoulder so that when the spark plug is tightened, the gap will point in the desired direction.
However, without running an engine on a dyno, it is impossible to gauge which type of indexing works best in your engine. While most engines like the spark plug's gap open to the intake valve, there are still other combinations that make more power with the gap pointed toward the exhaust valve.
In any case, engines with indexed spark plugs will typically make only a few more horsepower, typically less than 1% of total engine output. For a 500hp engine, you'd be lucky to get 5hp. While there are exceptions, the bottom line is that without a dyno, gauging success will be difficult.
Old Sep 13, 2007 | 12:10 PM
Default Re: Spark Plug Orientation? (satitus)
hey, a 1% increase for doing something that is pretty much painless, and free, i'll take it
Old Oct 21, 2011 | 12:20 PM
Bryan_Pendleton's Avatar
Anyone have any data or experience to support a given plug orientation on Honda motors?
Old Oct 22, 2011 | 11:53 AM
7rrivera7's Avatar
Old Oct 22, 2011 | 12:48 PM
todahead's Avatar
wait i miss something here ?
or the open end of the plug, faces the intake side of your cylinder head ?
Old Oct 22, 2011 | 01:29 PM
FlewByU352's Avatar
I've always heard face the open end towards the intake valves. With how deep down they are on our motors it is a pain in the *** and I have never done it for that reason. Tightening them down until they are facing the correct direction just sounds like a great way to overtighten them. That you you pull the plug out again and rotate it then start threading it into the hole again.
Old Oct 23, 2011 | 02:08 AM
N/A's Avatar
N/A
Purpose Built
As stated before, it varies on different setups
Most like the ground strap towards the exhaust..
Not really soomethin you want to put too much thought into. Results aren't worth the effort, your better off worrying about the heat range.
ravinaziankid
Aug 14, 2012 05:25 PM
Scharged2000GsR
Oct 14, 2003 05:05 PM
Mefain
Jun 3, 2003 10:15 AM
