double valve spring BROKE...
Old Jun 16, 2002 | 06:30 PM
builthatch's Avatar
MiG-21 superfan
Default double valve spring BROKE...
on my fullbuild y8, one of my WEB double valve springs broke, the outer one...so i towed it home, pulled the head, and everything is golden...no piston to valve, nothing that i can see. whew! BUT...this is my question; should I replace the springs (inner and outer) for that one valve, or should I go with another brand for all 16 valves? they were pricey, so just dumpin' them would suck $-wise, but im honestly shook of their integrity now...SHOULD I SEE IF WEB WILL SOMEHOW COMPENSATE ME SO I CAN GET ANTOHER BRAND? what would yous do?
Old Jun 16, 2002 | 06:37 PM
JV's Avatar
JV
Who?
Default Re: double valve spring BROKE... (builthatch)
I'd check out the warranty first, see if they'll compensate or replace the product. If that does'nt work out then i'd dump em like a hot potato. I've seen broken JUN cams before so it's most probably a just freak thing. What were you doing at the time........?
Old Jun 16, 2002 | 06:41 PM
builthatch's Avatar
MiG-21 superfan
Default Re: double valve spring BROKE... (JV)
sad thing is, i was just driving @ 3k rpm...nothing out of the ordinary, had not hit 8500 rpm in a few days...im sying when one valve spring breaks in 7k miles, im def sketched about the other 15 (30 if you consider they are dubble)
Old Jun 16, 2002 | 07:08 PM
JV's Avatar
JV
Who?
Well, you have obviously lost all faith in the product ( And i don't blame you). Just try to get them to compensate you , then replace them with something else.....
Old Jun 16, 2002 | 07:26 PM
builthatch's Avatar
MiG-21 superfan
yeah ill see what happens tomorrow, ill keep ya posted incase it happens to ya! ONE
Old Jun 17, 2002 | 12:23 AM
Halo's Avatar
I am running the WEB valvetrain also, please keep us updated if web honors their warranties. What kind of cam were you running?
Old Jun 17, 2002 | 01:30 AM
ninesecrx's Avatar
Default Re: double valve spring BROKE... (Halo)
Web springs are bad ***. I rev to 10,000rpm on them in my race car. Are you sure the install was done correct? It would have to of been a freak accident other wise because I know plenty of people putting a ton of abuse on them.
Old Jun 17, 2002 | 09:57 AM
builthatch's Avatar
MiG-21 superfan
Default Re: double valve spring BROKE... (ninesecrx)
install height to web spec...i called web and they will replace it on the werd of my machinist, but nonetheless, i am going with crower spring and retainer kit now...so, the web double valve springs and ti retainers are for sale. 32 springs total and 16 retainers w/ shims and locators. 7 k miles. email builthatch609@aol.com
Old Jun 17, 2002 | 11:23 AM
GreenD's Avatar
im running the Web kit also. any idea why it broke? r they replacing all the outters or just the one?
Old Jun 17, 2002 | 02:43 PM
builthatch's Avatar
MiG-21 superfan
Default Re: double valve spring BROKE... (GreenDestiny)
they are replacing inner and outer for the one valve only...makes it easier to sell the webs to recoup for the crower set i just got...
Old Jun 17, 2002 | 07:30 PM
Ltech's Avatar
Why not go with ferrea? They are expensive but worth the money.
jason phan
Old Jun 18, 2002 | 06:54 AM
builthatch's Avatar
MiG-21 superfan
Default Re: double valve spring BROKE... (Ltech)
crower's springs are eibach springs...in my opinion, no better spring manufacturer...ferrea is dope too but crower is top notch and 260$ for the best ti retainers and springs is decent in my book.
Old Jun 19, 2002 | 12:41 AM
kinesistech's Avatar
Whats up builthatch
I've seen that happen on Porsche's before. Its not common but it is possible. I would just replace both springs on that valve. I couldnt justify buying a whole new set just for one broken spring.
Old Jun 19, 2002 | 12:48 AM
Rocket's Avatar
Default Re: double valve spring BROKE... (kinesistech)
May I ask, are you running a lightweight flywheel?
Also what kind of cams do you have?
Curious.
Thanks.
Old Jun 19, 2002 | 06:08 AM
builthatch's Avatar
MiG-21 superfan
Default Re: double valve spring BROKE... (Rocket)
YO RYAN! eh, i ended up installing the crower kit and am selling the webs and ti retainers...im too shook from that one breaking. started it up last nite and am very pleased, 275+ across the board, i changed the head gasket cuz i'd a small leak in # 4 anyway before the spring broke.
ROCKET, im running a clutchmasters alum. flywheel and a web camshaft, soon to be crower stage3, i want to crack 170 whp.
Old Jun 19, 2002 | 08:00 AM
Rocket's Avatar
I suspected a light flywheel. What are the specs on the Web cam?
Engine rotation is more "jerky" with a lighter flywheel and will put more instaneous accelearation on the springs so even though you didn't run mad rpm your springs are still experiencing alot of shock.
State.of.Prime
Oct 17, 2010 01:43 PM
Grand
Aug 31, 2005 01:36 PM
Arturbo
Feb 9, 2004 02:26 AM
Stryker908
Aug 12, 2003 09:58 AM
