Few questions on my new turbo build.
I have 2 questions.
1:
right now i have stock h22a4 turbo. somewhat tuned. put bigger exhaust on (stock vs 3in) My question is if i get it tuned with stock motor then rebuild an put 8.5.1 in that will make it run rich..right? so ill be okay to use that map before i get it tuned after rebuild.
2:
My next question is Im running some DSM 450's with a t3/t4 60 trim .63ar. what are we looking at for power before them are injectors are at its maxed? 300whp? maybe more? what PSI range do you think they can handle?
Thanks fellas
_george
1:
2:
Thanks fellas
_george
with the h22 you will max out the injectors theoretically faster than a 1.8 b series because f the bigger displacement.
with the 8.5:1s you may not run richer but the engine will love alot more timing.
Ryhaz
Jun 8, 2014 03:21 PM
racinskittle
Aug 31, 2004 10:27 PM
