question about moroso oil pan
Old Sep 11, 2007 | 11:29 PM
jdm2ltrcpe's Avatar
Default question about moroso oil pan
like the title says i have a question about the modified oem replacement oil pan. i put it on and it started leaking ffrom the front corner by the crank pulley. so i took the oil pan off and and i noticed in the gasket that there was 2 rips where nipple goes. so i put a new gasket on and used silicone and it still does the same thing. I put alot of rtv around the outside of the block and pan and it still manages to leak. So i wonderin if anyone else has had this problem and if they did how did they fix it. thanks in adance
Old Sep 12, 2007 | 05:52 AM
kameleon23's Avatar
Default Re: question about moroso oil pan (jdm2ltrcpe)
I had a steel moroso pan that leaked where they spot welded the baffle in it...u need to call moroso and explain to them that it wont seal if you are having problems with it.
Old Sep 13, 2007 | 08:54 AM
jdm2ltrcpe's Avatar
anyone else got any opinions or ideas.
Old Sep 13, 2007 | 09:25 AM
patrick4588's Avatar
did you over tighten the pan? i have heard of it leaking because ppl over tightened it and the gasket was not sealing because of it. re torque everything to spec. i would also check to make sure that the mating surface is clean and nothing is preventing the gasket from sealing properly
Old Sep 13, 2007 | 04:01 PM
rmcdaniels's Avatar
I heard the old aluminum ones didn't like to seal. My new steel Moroso RR pan seals fine.
Old Sep 13, 2007 | 04:49 PM
sc4dr's Avatar
Default Re: question about moroso oil pan (rmcdaniels)
Yeah man, I love my steel rr pan, lots of cool trap doors
Old Sep 13, 2007 | 04:59 PM
BoostedEF_d16z6's Avatar
i had the same thing happen to mine but it wasnt the gasket it was the crank seal.....it had alittle rip in it and it looked like it was comin from the oil pan but it wasnt that
Old Sep 13, 2007 | 05:47 PM
sc4dr's Avatar
Default Re: question about moroso oil pan (BoostedEF_d16z6)
Thats very possible.
Old Sep 13, 2007 | 06:14 PM
turbo-crx's Avatar
Default Re: question about moroso oil pan (sc4dr)
Yea That Pan Is A Piece Mine Leaks In The Same Spot. Iv Tried 100 Different Gaskets And Sealants And It Still Leaks
Old Sep 13, 2007 | 08:43 PM
turboaap's Avatar
Default Re: question about moroso oil pan (turbo-crx)
Mine was cracked on the weld for the oil drain. Thought it was the gasket to. just welded it backup. Its fine now. look at the welds good. goodluck
Old Sep 17, 2007 | 09:07 AM
mrlegoman's Avatar
Default Re: question about moroso oil pan (turboaap)
I've got a semi-new 5-grt pan and I have not have any leak issues. Just used a new OEM gasket every time a take it off and I remind myself no to overtighten.
rxff91
Jun 12, 2009 05:59 AM
trooper0641
14
Oct 11, 2005 07:11 PM
deconstruct
Jun 18, 2004 01:00 PM
THE GAME IS THICK
May 21, 2004 02:41 PM
MR. ARIZONA
Sep 3, 2003 05:04 PM
