renting crankshaft puller
Old Jun 16, 2002 | 05:02 PM
ImportHatch's Avatar
Default renting crankshaft puller
Is there anywhere I can rent a tool to take my crankshaft pulley off. I'm havin a heck of a time getting it off.....I've pretty much ran outta stuff to try. Thanks.
Yager-
Old Jun 16, 2002 | 05:46 PM
Default Re: renting crankshaft puller (ImportHatch)
something like this....
Yager-
Old Jun 16, 2002 | 05:50 PM
B19CivicHB's Avatar
Is the engine out of the car? If it is, I just wedged a cloth covered screwdriver in the teeth of the flywheel and then into one of the many spaces in the block. I held that while my dad went to town on the bolt with a breaker bar. 15 minutes worth of cussing and it came right off. Might even help to slip a slightly larger diameter tube over the breaker bar for increased mechanical advantage.
HTH.
-Nick-
Old Jun 16, 2002 | 05:56 PM
Default Re: renting crankshaft puller (B19CivicHB)
Motor is in the car...have been trying for 5 hours to get it off. Tried everything........I'm to the point of blowing up my car.
Yager-
Old Jun 16, 2002 | 06:09 PM
B19CivicHB's Avatar
do you have the tranny off?
Old Jun 16, 2002 | 06:34 PM
Unsung's Avatar
Tranny is still on the car.
Old Jun 16, 2002 | 06:36 PM
Ausmith's Avatar
I'd let you use mine if yuu weren't 2000 miles away
Old Jun 16, 2002 | 06:40 PM
blackEF's Avatar
Default Re: renting crankshaft puller (Ausmith)
just get a helper monkey
Old Jun 16, 2002 | 06:41 PM
Unsung's Avatar
Default Re: renting crankshaft puller (blackEF)
Just go home Barry...
Old Jun 16, 2002 | 06:45 PM
Default Re: renting crankshaft puller (JDM B-Series)
helper monkey will not help here....
Yager-
Old Jun 16, 2002 | 09:31 PM
earl's Avatar
A big impact wrench will overpower the bolt to take it off. See if you can borrow or rent an electric one.
Old Jun 17, 2002 | 07:49 AM
CovertFI's Avatar
Default Re: renting crankshaft puller (earl)
summit sells the crank tool for 65 with a long handel!! just go in half with your buddy.
Old Jun 17, 2002 | 10:32 AM
LoudLude's Avatar
If the car is driveable, pack it up and take it to a local shop. They can use their 1/2" impact with house air to break it. Then have them torque it down just enough to get you home.
Option 2 would be to buy/rent a chain wrench. It will hold the pulley, but may also induce damage to it.
Option 3 would be to buy my tool from me. If that hex opening measures 2in. from side to side, my tool would fit.
Old Jun 17, 2002 | 10:56 AM
Avante's Avatar
Default Re: renting crankshaft puller (LoudLude)
Get the tool somehow, either borrow one from a friend if they happen to hve one, or buy one from summit or etoolcart.com IN any case DONT use an impact wrench!
Old Jun 17, 2002 | 12:51 PM
deez92's Avatar
Default Re: renting crankshaft puller (Avante)
i use an impact everytime, no problems yet
Old Jun 17, 2002 | 01:20 PM
Stewie's Avatar
Default Re: renting crankshaft puller (deez92)
I used a chain wrench with a belt wrapped around the pulley.
Old Jun 17, 2002 | 01:23 PM
AutoXsi2000's Avatar
how bout this, leave the wrench and the socket on the pulley nut. leave it so that the wrench is unable to rotate, that means having the wrench touching the ground. next depending how the crank rotates, you can now turn the car, of course that means turning your car keys in the ignition for a sec or until the bolt comes loose. This will allow the bolt to come loose for the crank. If anyone can confirm the rotation of the crank.
Old Jun 17, 2002 | 01:25 PM
Default Re: renting crankshaft puller (mano77)
You are thinking what I was thinking. I kept saying this and everyone was like....Whoa, your crazy. What if it starts? and i was like...well i'll just cut fuel and it wont. And my stepdad didnt like that idea....at least I know someone is thinkin like me.. But one thing I havent checked is which way the bolt turns while the motor is crankin.....
Yager-
[Modified by ImportHatch, 2:26 PM 6/17/2002]
Old Jun 17, 2002 | 01:29 PM
i did this to my nissan maxima, it worked fine, just gave it a quick crank a couple of times, the bolt came loose. Learned that from one of the Master techs.
Old Jun 17, 2002 | 06:16 PM
GruvyTune's Avatar
New User
the bolt turns counterclockwise with the car running. You can do it this way!
I recommend another way that I found very easy to do this past weekend. I have the special tool and it is worth getting buy I was trying to take an Unorthodox Pulley off (its for sale by the way) and it has no place to put that "special tool".
Anyway, after lots of cursing, I found someones suggestion about fashioning a brace for the flywheel. Just take off the 2 brackets and the cover plate that covers the inspection window for the flywheel (its near the oilpan junction with the tranny). Then, take some of that metal bracket material from a hardware store with the holes in it and drill one out to accomodate one of the screws that holds that cover plate on. Put one hole of the bracket into one of those screw holes and the other into one of the screw holes in the flywheel (you don't need a screw, I just jammed an appropriate size hex wrench in there to hold it). Now you can crank all you want on your crank pulley bolt and it will come right off!
good luck, this method is foolproof. Works great to get the bolt back on to the right torque again too.
menappi
15
Apr 14, 2005 10:41 AM
jbell
20
Jan 1, 2005 09:09 PM
NgF
28
Jun 23, 2004 06:58 AM
Red D Dragon
Mar 10, 2004 12:48 PM
Bspec18
Nov 15, 2003 01:11 AM
