Bleeding the clutch line
I know for a fact I need to bleed my clutch line due to the fact that barley tapping my pedal creates it to drop to the floor so there has to be air in the line... but I dont know if that would cause me to not get the car in gear?? which is the problem.
Modified by crimenthecity777 at 8:10 PM 9/11/2007
I am having similar problem and see fluid on the clutch line where the rubber joins to the hard metal. I have no leaks in the master or slave cylinder. Unfortunately the line is pretty expensive.
sideswiped
Jun 13, 2010 01:35 PM
