92 hatch "BRAND NEW D16Z6" problems
Old Sep 11, 2007 | 05:14 PM
SpoolD16's Avatar
Default 92 hatch "BRAND NEW D16Z6" problems
i have a 92 hatch si and i just put a fully rebuilt D16Z6. im having a couple issues with it. first off my battery is losing its charge but the i tested the alternator and its perfect and i don't believe the battery is grounded anywhere. any ideas? second my clutch( stage 2) makes a cracking/crunching sound when i push it in. third is whenever i go to floor the gas i feel like the car goes nowhere. could it be due to my 2in exhaust pipping leading to a stock muffler(due to police tickets)? or exhaust leak? any ideas. im really stomp here. i really need feed back
Old Sep 11, 2007 | 09:51 PM
SpoolD16's Avatar
Default Re: 92 hatch "BRAND NEW D16Z6" problems (SpoolD16)
bump
Old Sep 11, 2007 | 10:08 PM
DCSportEJ1Civic's Avatar
as for the charging, check at the battery, and the alt. if theyre different theres a bad connection somewhere. as for the clutch, maybe not properly installed, or a bolt backed out, of a bad through out bearing maybe? these are just my suggestions of things to check. as for the power issue, maybe a bad or unhooked sensor. i dont think the exaust would cause that. id say start checking everything.
Old Sep 11, 2007 | 10:15 PM
SpoolD16's Avatar
well i think i will check the clutch but im positive it was put in correctly. and has a new throughout bearing. connections at battery an alternator are good. could it be the distributor?
Old Sep 11, 2007 | 10:35 PM
check spark. idk if it would be the dizzy but i guess it could. i would think that would keep it from runnin all together. maybe bad spark plug wires? or incorrect plug gap? theres a lot off different things it could be. its just a matter if checking them one by one untill you find what it is.
Old Sep 12, 2007 | 12:29 PM
SpoolD16's Avatar
Default Re: 92 hatch "BRAND NEW D16Z6" problems (DCSportEJ1Civic)
bump
Old Sep 12, 2007 | 12:45 PM
spoon_concept_eg6's Avatar
hey for the battery problem my 92 eg has this problem sometimes. all i do is poor a little pepsi on that positive turminal. sometimes the wire starts to corrotes inside so that can cause it to week out the charge. or just connect a ground from the battery to your engine. <-- i didnt need to do that. good luck
Old Sep 12, 2007 | 01:34 PM
crazyguy's Avatar
make sure the cable from alternator is connected to positve terminal of the battery
swizz977
34
Jan 4, 2012 04:58 PM
lv6l
Nov 14, 2008 03:40 PM
SpoolD16
11
Oct 2, 2007 06:50 PM
Hatched_out
42
Mar 13, 2007 01:42 PM
