WHAT SHOULD COMPRESSION ON A 96 JDM TYPE R BE?
Old Sep 11, 2007 | 07:33 AM
beef-cake's Avatar
Default WHAT SHOULD COMPRESSION ON A 96 JDM TYPE R BE?
LOOKING AT BUYING A 96 TYPE R MOTOR AND THE COMPRESSION IS AROUND 215, WONDERING IF THAT'S LEGIT, OR IF A JDM GSR WOULD HAVE 215 COMPRESSION.
BLOCK SAYS B18C BUT BOTH GSR AND TYPE R MOTORS FROM JAPAN HAD JUST THE B18C AND I DON'T WANNA GET SCREWED ON THIS.
Old Sep 11, 2007 | 07:56 AM
Mr. Carbon Fiber's Avatar
Default Re: WHAT SHOULD COMPRESSION ON A 96 JDM TYPE R BE? (beef-cake)
It should be 270psi across all cylinders: Team-integra compression how to
http://www.team-integra.net/se...=1086
Old Sep 11, 2007 | 10:34 PM
beef-cake's Avatar
Default Re: WHAT SHOULD COMPRESSION ON A 96 JDM TYPE R BE? (Mr. Carbon Fiber)
hmmm, it says no more than 270 and no less than 135. ???
Old Sep 12, 2007 | 12:20 AM
Stoich EG2's Avatar
the compression wont tell you what kind of motor it is. i had a b16 with 210 across all cylinders. my buddy's 96 R did 225. it all depends on the rings, headgasket, valves, etc and the condition
Old Sep 12, 2007 | 12:23 AM
tartje's Avatar
Default Re: WHAT SHOULD COMPRESSION ON A 96 JDM TYPE R BE? (Stoich EG2)
depends on the gauge too
look for consistency, not numbers
for a start it should be obvious on the inlet manifold, and if there isn't one there, the stud patterns
also the radiator hose inlet/outlets etc. are in different places
Doostur's Avatar
I have seen 220 across the board as well on a JDM ITR.
Old Sep 12, 2007 | 12:55 AM
tartje's Avatar
Default Re: (Doostur)
mine went off the gauge of 250+ on all cylinders
Old Sep 12, 2007 | 05:04 AM
sheekdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beef-cake &raquo;</TD></TR><TR><TD CLASS="quote">BLOCK SAYS B18C BUT BOTH GSR AND TYPE R MOTORS FROM JAPAN HAD JUST THE B18C AND I DON'T WANNA GET SCREWED ON THIS.
Check the head casting next to the date... if it says p72 its a gsr, if it says pr3-3 its a type r. Also check between the oil filter and the block... i think only type r's come with an oil cooler. On the back of the block somewhere should be stamped in the casting p73, i don't remember where though.
There are more experts on here... Please chime in, i could be wrong.
Old Sep 12, 2007 | 06:25 AM
240sx1faster's Avatar
215
Old Sep 13, 2007 | 05:17 PM
beef-cake's Avatar
Default Re: WHAT SHOULD COMPRESSION ON A 96 JDM TYPE R BE? (240sx1faster)
Well though compression won't tell you what motor, I wanted to know what some people had for ratios, because if it was super off, then i'd just look for another engine.
HypL
May 12, 2014 05:42 PM
97EXB18C
May 23, 2009 11:08 PM
p-boy
Jan 20, 2003 10:13 PM
VTEC-DA
Jan 6, 2003 05:48 PM
StudioJDM
Jan 3, 2003 11:25 AM
