rpm gauge going nutz whats happening?
Old Sep 11, 2007 | 04:27 AM
Pichy's Avatar
Default rpm gauge going nutz whats happening?
i have a 1996 civic dx
i swapped the dx cluster to an ex cluster.
it was working fine until like 5 days ago (been in there for over a month now) the tach started jumping for joy all of the sudden. i start the car up and it goes all the way around and it stays there for while then it goes back to normal.. then when im driving once in a while it goes crazy again..
here is the evidence
20mph @ 8000rpms...LMAO ******* rice
and idling @ almost 3000rpms
yet the car runs really smooth and the engine is idling normal..
im thinking the distributor is going bad.. but wouldn't the car be acting up?
in my forum their saying its a bad ground which makes more sense.. but yet idk
i cant find where the ground for the distributor is located..
the engine is a d16y7..
anyone know or had this problem b4? ive searched but came up empty.. idk if im searching on the right word or topic
any help would be appreciated
thx
Old Sep 11, 2007 | 04:43 AM
yoffer's Avatar
Banned
Im thinking that its a ground. The grounds for the distributor are located on the thermostat. Take them off and get the connections clean.
Old Sep 11, 2007 | 05:03 AM
Pichy's Avatar
Default Re: (yoffer)
where is that located
Old Sep 11, 2007 | 05:06 AM
b16a3delsol's Avatar
Default Re: rpm gauge going nutz whats happening? (Pichy)
maybe try checking the connections to the back of the cluster maybe something is a litlle loose back there.
Old Sep 11, 2007 | 05:14 AM
Luserkid's Avatar
Default Re: rpm gauge going nutz whats happening? (b16a3delsol)
Does this happen only when your engine is on? Or does it happen when the cars in the ON position. If it happens with engine on, then its early signs of ignitor issues. If it happens in the ON position then its something in your wiring (possibly ground or power wire).
Old Sep 11, 2007 | 05:17 AM
Pichy's Avatar
got it.. now lets clean it up and see
Old Sep 11, 2007 | 05:19 AM
Pichy's Avatar
Default Re: (Pichy)
it happens when the engine is on.. ill try to clean the ground fisrt to see what happens.. it does look greenish.. ill take pics
Old Sep 11, 2007 | 06:19 AM
Pichy's Avatar
well i cleaned it up but i dint have sand paper so i did the best i could with what i had.. took a drive.. and it did it again but more constantly.. i came back and removed the cluster.. unplugged the harness and wiggled some wires put it back in.. i re touched up the ground but ill hit it better when i get some good stuff. ill let you know whats happening soon
Old Sep 11, 2007 | 06:31 AM
pgpbubble's Avatar
Default Re: (Pichy)
Check the power wire on the top of your alternator.
topshotta
10
Mar 31, 2016 07:55 AM
JDeez_1212
Sep 16, 2012 09:34 AM
Apex1972
Sep 26, 2011 06:28 PM
vtec8200
Jun 19, 2011 05:09 PM
CLBrackin
13
Jan 6, 2003 05:45 AM
