Civic Vs. Accord?
Old Sep 10, 2007 | 03:27 PM
96_Accord_lx's Avatar
Default Civic Vs. Accord?
Arent the civic and accord sohc engines the same? 4 drs i mean.
Old Sep 10, 2007 | 03:29 PM
TheMuffinMan's Avatar
He knows where you live!
exactly the same
this is why all the parts are interchangeable
(no, they are not the same at all, they have never been the same)
Old Sep 10, 2007 | 03:47 PM
The-Kid's Avatar
Default Re: (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">exactly the same
(no, they are not the same at all, they have never been the same)</TD></TR></TABLE>
ROFFLES!
Nope. A civic will never have a 2.2L engine. And a civic is smaller than the Accord. Therefore, no...
Old Sep 10, 2007 | 04:03 PM
I'd like to note I wasn't trying to be mean.
Just sarcastic to the 10th degree.
1) same motor in both 4/2 door cars (civics and accords) they didn't change them for that
2) you don't make note of the year at all
3) why would they have the same motor
4) what made you think they did?
civic's have been like 1.6L or 1.8L at most
Accords are 2.2 starting for the most part
There wasn't a lot of thought process before the post
Old Sep 10, 2007 | 04:37 PM
i just wanna say no there wasnt much thought put into this and i hardly ever work on accords so i have no idea but im getting one tomorrow... its a 95 lx sedan 2.2L and i dont know what to do to get the most HP out of it w/o swapping, strapped for cash atm... so i figured i could just pull a honda civic engine and swap it that way for easier tuning... guess not......
Old Sep 10, 2007 | 05:22 PM
haha no sir,
if you're looking for a motor swap for an accord
h22 from a prelude is essentially a direct bolt in, and 95 is OBDI so you're good to go tuning wise
you should also do some searching about turbos
Old Sep 10, 2007 | 06:13 PM
Raven_Accord's Avatar
Boosting an H22? i heard those engines are a little to weak to turbo... if its possible, and with a decent amount of boost(more than 5 to 7 punds), that engine could really pull hard!!!
Old Sep 10, 2007 | 07:13 PM
Default Re: (Raven_Accord)
well thanks but how much do they run? again im strapped for cash...
Old Sep 10, 2007 | 07:29 PM
Turbo the F = ~ $1000-1500 (depends on what you buy)
Swap the H = ~ $2000 or so (depends on who does it/etc)
Old Sep 11, 2007 | 06:21 PM
so i found a guy that can get me a prelude engine for 150... is that good? how much do they run to swap?
Old Sep 11, 2007 | 07:01 PM
GhostAccord's Avatar
Default Re: (95_Accord_lx)
$150 sounds to good to be true, so it probably is. Check what year and model Prelude it is. If it's a 92-95 Prelude S don't bother. It has a SOHC F22A1 and that's pretty much what you have in your Accord.
If it is an H22 for $150 It will probably need about $1000 worth of parts to get it running. The only on the cheap H I found was up in the $500-$750 range. That was bare bones nothing included. No sensors, equipment or ECU.
Old Sep 11, 2007 | 07:18 PM
well this guy is a real close friend of my old nieghbors so i will look into it, thanks for your input though!
hamesworth
11
Apr 6, 2008 10:31 AM
kcari
Honda Civic (2001 - 2005)
May 21, 2007 09:03 AM
IcebergMan
Mar 10, 2006 09:37 AM
93formula
May 1, 2005 06:34 PM
GoLowDrew
Acura TL, RL & ZDX
Jan 13, 2005 12:37 PM
