castle nut
Old Sep 10, 2007 | 03:05 PM
drewski101's Avatar
Default castle nut
So I just changed both axles and I can't seem to get the castle nuts back on. I can tighten them some of the way, but after the nut makes contact with the lower control arm the bolt in the joint just spins along with the nut. Anyone encounter this before?
Old Sep 10, 2007 | 03:08 PM
Bizarre's Avatar
Default Re: castle nut (drewski101)
The trick I use to get them to tighten on is put your jack under the lower control arm. Jack it up till the suspension fully compresses. Its basically when the jack is about to lift the car off the stand. Once you do that you should be able to torque them down properly.
Old Sep 10, 2007 | 03:19 PM
Crx Jimmy's Avatar
Default Re: castle nut (Bizarre)
You probably boogered up the threads getting them off, get a die and rethread it so the nut threads on nice and easy I think its a 10mm or 12mm x 1.25
Old Sep 10, 2007 | 03:43 PM
jdm206's Avatar
Default Re: castle nut (Crx Jimmy)
i also use the jack trick that Bizarre uses, it works evey time.
Old Sep 10, 2007 | 03:56 PM
DaNnYsEvEn's Avatar
Default Re: castle nut (jdm206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm206 &raquo;</TD></TR><TR><TD CLASS="quote">i also use the jack trick that Bizarre uses, it works evey time. </TD></TR></TABLE>
x2 works like a charm
Old Sep 10, 2007 | 04:33 PM
rice a roni's Avatar
if the jack stand thing doesnt work out for you...take a bar that will fit in between the knuckle and the ball joint and have someone push down on it while you impact it on...good luck.
Old Sep 10, 2007 | 04:49 PM
Tyson's Avatar
its because the balljoint is used and worn out. doesnt mean you necessarily have to replace the balljoint, but its just worn from normal use.
also the castle nut DOES stretch after use, especially because the threads are disrupted by 6 cuts at the end... so either:
buy a new castle nut, or buy a tap
12x1.25M for the lower balljoint.
10x1.25M for the tie rod and upper.
i always keep taps in my tool box.
Old Sep 10, 2007 | 04:53 PM
Tyson's Avatar
btw, thats some nice pics of the balljoint!
nice camera...
Old Sep 10, 2007 | 05:22 PM
garageEF's Avatar
Default Re: castle nut (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">btw, thats some nice pics of the balljoint!
nice camera...</TD></TR></TABLE>
x2....what camera?
Old Sep 10, 2007 | 05:42 PM
Crx Jimmy's Avatar
Default Re: castle nut (garageEF)
That nut looks boogered up too I would replace it with a new one as well
Old Sep 10, 2007 | 06:02 PM
drewski101's Avatar
Thanks for the replies everyone, I got them on. I had to grind down one of the bolts because the threads were mangled, so I had to use lock-tight instead of a cotter pin.
It works for now though, my parents wanted the car out of the driveway, and I think I'll eventually have to get new ball joints anyway like Tyson said.
Btw, camera is a Canon Digital Rebel XTi with the stock lense, and it was on auto.
Old Sep 11, 2007 | 05:19 AM
Hondaisok's Avatar
What I use in this case is a 4" C clamp. Put one end on top of the ball joint and one end on the knuckle and tighten, doesn't take much pressure to stop the stud from turning. Also, be careful not to overtighten the castle nut.
allums34
Apr 13, 2011 09:55 AM
beanbag
Suspension & Brakes
Feb 11, 2009 06:04 AM
zx2gotboost
12
Dec 28, 2005 12:20 AM
integra95gsr
Dec 5, 2005 11:06 PM
ScottEK
17
Sep 21, 2002 06:23 PM
