cam gears worth it?
Old Jun 16, 2002 | 12:24 PM
STEALTHMODECOUPE's Avatar
Default cam gears worth it?
on a j-spec gsr motor with all the bolt ons and some skunk2 cams(not sure what stage to get just yet)..should i get the cam gears while im at it or not worth it..also will it mess up the motor if im running nitrous cause i heard your not supposed to use nitrous and advace the timing?? thanks much
Old Jun 16, 2002 | 12:30 PM
rodrez.'s Avatar
Default Re: cam gears worth it? (STEALTHMODECOUPE)
if you plan to get the car dyno tuned, I highly recommend adj cam gears along with an FPR, they make a huge difference in power. Just let the tuner know that you're going to be squeezing, and he can take the necessary precautions.
2kdrift
Mar 15, 2016 02:32 PM
RED_90TEG
May 11, 2008 01:23 PM
theleftis
Jan 17, 2006 04:10 AM
blackdelslo
Aug 18, 2004 06:19 AM
Inextricabledrvr
May 10, 2004 07:38 AM
