check these out
Old Sep 10, 2007 | 11:30 AM
hatch96y7's Avatar
Default check these out
are these goo cables or are they overpriced http://store.summitracing.com/...w=sku
Old Sep 10, 2007 | 11:42 AM
EL Vap133's Avatar
Default Re: check these out (hatch96y7)
Overpriced, I got mine for like $30 or so.
Old Sep 10, 2007 | 01:11 PM
hatch96y7's Avatar
Default Re: check these out (EL Vap133)
where at please let me know
Old Sep 10, 2007 | 01:12 PM
gsxr1k05's Avatar
x2 i wanna know..
Old Sep 10, 2007 | 01:51 PM
built562's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Overpriced, I got mine for like $30 or so. </TD></TR></TABLE>
are you sure they are the same ones.... ngk makes different types of wires from OEM to 'high performance'.
Old Sep 10, 2007 | 01:55 PM
Eran's Avatar
HT White Ops
You can get other NGK ones for $30 that are about equivalent to the OEM plug wires.
Those $100 plug wires will net you all of zero gains and a $70 loss.
Old Sep 10, 2007 | 04:58 PM
ProjectEJ2's Avatar
So, where 30dlls ones at?
Old Sep 10, 2007 | 05:41 PM
Dav94Lx's Avatar
Where'd you gettem dude???
Old Sep 11, 2007 | 08:27 AM
hatch96y7's Avatar
Default Re: check these out (Dav94Lx)
WHERE R THEY AT
Old Sep 11, 2007 | 09:11 AM
b16a3delsol's Avatar
they are probably just an oem equivalent if he got them for 30 bucks but I still want to know where.
Old Sep 11, 2007 | 09:27 AM
hatch96y7's Avatar
Default Re: check these out (b16a3delsol)
oh i am looking fo ngk not thesehttp://www.partsamerica.com/pr...Set=A
Old Sep 11, 2007 | 09:47 AM
roycivic92's Avatar
ngk is always a good product, honda recomends ngk plugs for a reason, so i guess ngk wires also work good. I guess its like car audio equipment, alpine works good with alpine. I personaly prefer msd wires, never had a problem.
Old Sep 11, 2007 | 09:49 AM
hatch96y7's Avatar
Default Re: check these out (roycivic92)
every one always suggest ngk but for an upgade what should be used instead.
for better spark i guess.
because i heard the msd ign system losses power.?
Old Sep 11, 2007 | 10:00 AM
roycivic92's Avatar
true i heard that too, but for a stock motor ,how much hp can u lose on the wires .5 hp or 1 hp. dragster use msd wires for a reason ,there reliable. I dont want wires that will give me 1 extra hp and for them to go bad in a year. Ive had my wires for about 2 years with out worries.
Old Sep 11, 2007 | 10:01 AM
smileycvc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">every one always suggest ngk but for an upgade what should be used instead.
because i heard the msd ign system losses power.? </TD></TR></TABLE>
Everyone suggest NGK becuase there really isnt anything better. You can upgrade to "performance wires" but your not going to see any gains and just waste your money. Unless your making a ton of power through high boost or somthing and you need a stronger/longer spark then you can go with msd.
Old Sep 11, 2007 | 10:43 AM
hatch96y7's Avatar
Default Re: check these out (smileycvc)
got it .
so where can i pick these ngk's up at i live in la and no one sells them
turismo128
Dec 31, 2007 06:01 PM
david
21
Nov 23, 2005 07:32 AM
Slowboy!
32
Nov 11, 2005 07:18 AM
ochsy03
Jun 26, 2005 09:47 PM
DieMaster
56
Sep 19, 2004 11:23 AM
