did my swap dont know where they go!! please help
Old Sep 10, 2007 | 11:19 AM
unrealgtx's Avatar
Default did my swap dont know where they go!! please help
hey guys i did my swap over the weekend and i hooked everything up for the most part im just unsure of where 2 things go , which is the hose at the end of the fuel rail and some other hose that i dont know about please check the pictures out and help me out
http://img129.imageshack.us/im...8.jpg this is under the little yellow thing i think it goes to the car for fuel
http://img129.imageshack.us/im...6.jpg this one is the last one which connects to the bottom of the throttle body but idk if u can see it
please help me out thanks...
Old Sep 10, 2007 | 01:02 PM
AWD Terror's Avatar
Default Re: did my swap dont know where they go!! please help (unrealgtx)
You need to circle the things in your pics, or just get better ones. I don't see anything wrong
Old Sep 10, 2007 | 01:20 PM
StockDC2's Avatar
Default Re: did my swap dont know where they go!! please help (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">You need to circle the things in your pics, or just get better ones. I don't see anything wrong</TD></TR></TABLE>
Old Sep 10, 2007 | 01:21 PM
roger93si's Avatar
x3
Old Sep 10, 2007 | 02:46 PM
unrealgtx's Avatar
Default Re: did my swap dont know where they go!! please help (roger93si)
http://img294.imageshack.us/im...5.jpg
http://img294.imageshack.us/im...1.jpg
i know where they start but i dont know know where the go into to maybe this is better
Old Sep 10, 2007 | 03:59 PM
g2daturbo's Avatar
goes from there to the hosing where the upper hose is... should be a small nipple on the back side
Old Sep 10, 2007 | 04:01 PM
g2daturbo's Avatar
Default Re: did my swap dont know where they go!! please help (g2daturbo)
the first picture the line comes from the throttle body and goes to a small nipple on the coolant neck where the upper hose connects. the second pic is the fuel return line... should come off the fpr and go down to the firewall
Old Sep 10, 2007 | 04:02 PM
g2daturbo's Avatar
let me know how you make out
Old Sep 10, 2007 | 06:21 PM
roger93si's Avatar
the first pic is one of your small coolant lines.
it connects to the head by the coolant sending unit.
the second pic connects to the firewall. u should have that line already on your car. take the one frome the motor off and connect the one fron your car.
Old Sep 10, 2007 | 06:36 PM
unrealgtx's Avatar
ok so the firewall im assuming is the wall of the car right? and uhh yea i had took it off by accident but im assuming its the fuel return. i hooked up everything i think. except im unsure of one more. let me explain: on the back of the engine(b20b) theres that giant metal hose the runs along the back and like in the middle of it theres one hose. well yea its still hanging there not connected to anything , if anyone knows where this might go please fill me in . thanks.
Old Sep 10, 2007 | 07:15 PM
Mfoehrkolb's Avatar
? - did you do this swap by yourself?
Old Sep 10, 2007 | 07:39 PM
db1_jdm's Avatar
Default Re: (Mfoehrkolb)
fuel return line, yes thats preety important!
Old Sep 10, 2007 | 08:23 PM
SoTexDC2's Avatar
Default Re: (unrealgtx)
In your pictures, the first one with the hardline shows the valve cover to intake arm hose, and the coolant hardline which goes between the throttle body and the head, next to the upper radiator hose. It's near the ECT sensor. # 17 pictured below.
The second picture is your fuel return line, which connects on the firewall - # 19 below.
The other description above that isn't pictured, is the water pump to thermostat housing coolant pipe (pictured below). Yours should have two ports, the left goes to the heater outlet pipe, disregard the middle outlet as it is for models with an oil cooler (not yours), and the right feeds the Idle Air Control Valve.
Close up of the coolant pipe:
Old Sep 10, 2007 | 08:51 PM
unrealgtx's Avatar
yea i swapped it by myself
Old Sep 10, 2007 | 09:08 PM
db1_jdm's Avatar
Default Re: (SoTexDC2)
finnaly someone that know what their talking about
Old Sep 10, 2007 | 10:09 PM
unrealgtx's Avatar
Default Re: (db1_jdm)
lets just say i hooked up one hose wrong........ dpeneding on what it is. im assuming it could ruin my car lol
Old Sep 16, 2007 | 08:42 AM
db1_jdm's Avatar
hahaha what did u do?
Rafal
Mar 11, 2007 12:40 AM
RyanG
Jan 4, 2007 12:18 PM
myhondasrusty
Nov 9, 2006 05:45 PM
HaUTSaauce
Sep 27, 2003 07:01 PM
