HELP car dont want to start
Old Sep 10, 2007 | 08:58 AM
pcp 914's Avatar
Default HELP car dont want to start
i need help figuring out y my car dont want to start. It clicks over like it wants to start up but dosnt pull all the way through. Its not the distributor or the starter. All i can think of is mayb the timming belt. can anyone help me or have any suggestions on wat it might b
Old Sep 10, 2007 | 09:21 AM
Dave_B's Avatar
Recent changes? Recent mods? Recent work?
It's one of 2 things... Spark or Fuel.
Old Sep 10, 2007 | 09:25 AM
Dave-ROR's Avatar
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">It's one of 2 things... Spark or Fuel.</TD></TR></TABLE>
What he said. Althoguh I'd say it's one of three, spark, timing or fuel, but you could combine spark and timing
How do you know it's not the dist? have you replaced it? what troubleshooting steps have you done, post that first so no one repeats things you've already done.
Old Sep 10, 2007 | 09:53 AM
pcp 914's Avatar
Default Re: (Dave-ROR)
i switch out the distrb so its not that. also the car has been sittin unstarted 4 a while.
Old Sep 10, 2007 | 10:01 AM
Dave_B's Avatar
Are you getting spark? Fuel? Check those first.
Old Sep 10, 2007 | 10:09 AM
pcp 914's Avatar
yea i have both
Old Sep 10, 2007 | 10:11 AM
Dave_B's Avatar
Apparently not, or not enough if the car isn't starting...
One way I use to test plug spark is to "ground" it on the car with the plug still plugged in. Use the electrode on the bottom to "ground" it out. Then have a friend try to crank the car. See if you get spark on the plug. If so... move to the next. Determine if any are not sparking. Then go back and determine why.
If the car has been sitting, maybe it's bad gas. Flush the tank and fill with fresh fuel.
Old Sep 10, 2007 | 11:33 AM
Dave-ROR's Avatar
Default Re: (pcp 914)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcp 914 &raquo;</TD></TR><TR><TD CLASS="quote">i switch out the distrb so its not that. also the car has been sittin unstarted 4 a while. </TD></TR></TABLE>
Ran fine before you shut it down? Any fuel treatment? You sure the gas is good? You sure it's getting fuel?
If you are getting spark and fuel (and the fuel is good), then timing.
What did you do to the car when it wasn't running?
Old Sep 10, 2007 | 12:26 PM
citrus3000psi's Avatar
I just don't get it. We have people here trying to help you, writing complete sentences and paragraphs. Most of this post just seems to be us trying to figure out what you've done to the car to not make it run.
All you have told us is:
yea i have both
Gives us some more information and we might be able to help you. From your quick replys like 'have both spark and fuel'. Might you tell us how you found this out?
Why did you replace the dizzy? Did you replace the dizzy before or after the car sat. Why did you replace the dizzy? Did anything look wrong with the previous dizzy? Is this dizzy confirmed working or new? Did you install the dizzy correctly? Are the wires connected to the right cylinders. If you give us a nice history of the car, the diag will be that much easy.
Old Sep 10, 2007 | 12:28 PM
JDM knowledge's Avatar
Default Re: (citrus3000psi)
take off your intake pipe maybe your not getting enough air in. It happens.
Old Sep 10, 2007 | 12:33 PM
Default Re: (JDM knowledge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM knowledge &raquo;</TD></TR><TR><TD CLASS="quote">take off your intake pipe maybe your not getting enough air in. It happens.</TD></TR></TABLE>
Wouldnt the more logical response be "Check to make sure the intake isn't clogged" If its sooo clogged the car wont start Im sure there will be something physcally noticable on the filter itself.
Old Sep 10, 2007 | 12:49 PM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah I've seen that happen on 2 stroke 40cc motors (mini bikes ) but not on a B series motor, and I've seen some really during filters on them. I'm not saying it's impossible, but it should be pretty visibly obvious.
Old Dec 19, 2007 | 05:53 PM
mars-EF-LS's Avatar
Same Problem anyone figure it out
Old Dec 20, 2007 | 03:16 PM
Boosted_01 R's Avatar
Fuel Relay under the dash????
Had the same problem, on my other Integra, turned out it was the dizzy.
Old Dec 20, 2007 | 08:23 PM
thekid03's Avatar
Default Re: HELP car dont want to start (pcp 914)
I'm still trying to figure what a timming belt is.
When you sleep in your car each night do you arm the car security system? Make sure it's not enabled when you try and start it.
I'd also check the Schroeder valve in your oil pan
Herbie
Apr 21, 2010 09:57 AM
vtecsi00
10
Feb 25, 2008 06:44 PM
boostinh22
May 6, 2006 05:02 PM
Stage587
Jun 12, 2005 02:28 PM
95civickid
11
Apr 5, 2005 05:52 PM
