Which starter?
Old Sep 10, 2007 | 08:40 AM
Local's Avatar
Default Which starter?
In the middle of replacing my starter right now. all was good until i took out my original & noticed it was quite a bit different then my newer one that i just purchased from LsPride who i found on this forum. my tranny is a cable ys1 and the teeth on the original starter has the teeth sticking out about an 1.5 inches and the one i just got the teeth only stick out about .5 inches at the most. the whole part that goes into the tranny is different.
so my question is are different starters required for different trans.? or whats the deal?
ORIGINAL:
REPLACEMENT:
thanks in advance
Old Sep 10, 2007 | 09:12 AM
Local's Avatar
Default Re: Which starter? (Local)
BUMP because i want to drive my car
Old Sep 10, 2007 | 03:16 PM
Local's Avatar
bump
Old Sep 11, 2007 | 07:51 AM
Local's Avatar
bizzump
Old Sep 11, 2007 | 08:06 AM
St Jimmy's Avatar
* B A N N E D *
Will it bolt up? Whats stopping you from trying it?
Old Sep 11, 2007 | 08:21 AM
Local's Avatar
Default Re: Which starter? (St Jimmy)
damaging the flywheel
worried that it may break teeth off the flywheel or just not be to pretty once i turn that key
Old Sep 11, 2007 | 10:41 AM
lude27's Avatar
are you sure your original starter isn't just seized out? the teeth kick out when power is actually given to the starter.
Old Sep 11, 2007 | 03:44 PM
stumpyf4's Avatar
Give it a try. If it grinds only once it's not gonna damage anything. Repetitive grinds eventually will.
Old Sep 11, 2007 | 06:50 PM
VTEC_PRODUCTION's Avatar
Default Re: Which starter? (stumpyf4)
yea, it looks like the same thing...and the older one just looks stuck out...when power is applied that shaft comes out to turn the flywheel and when its not engaged it pops back in like a turtle...bolt it up homie...not much can go wrong...just dont force anything...
jdm89civic
Sep 3, 2009 11:52 PM
effg714
Mar 28, 2008 10:59 AM
Local
Sep 12, 2007 02:05 PM
hondachris1994
Aug 3, 2006 02:03 PM
jmonee112
Aug 27, 2005 09:23 PM
