how old will a walbro 255 fuel pump last?
Old Sep 9, 2007 | 09:40 PM
the.hamburglar's Avatar
Default how old will a walbro 255 fuel pump last?
the reason why im asking this question is because i have had mine for about 3 years now (boosted all the time) and my car is now bogging really bad when i get into about 5psi. i raced all day today and it was fine, but when driving home i went to pass someone and it completly cut out it seemed. so can they fail that fast? i probably have about 10k on the pump
Old Sep 9, 2007 | 10:18 PM
esedulerp5tenin's Avatar
Default Re: how old will a walbro 255 fuel pump last? (the.hamburglar)
usually the sign for when fuel pumps are about to fail is the car gets harder to start. at least thats how mine went out.
Old Sep 9, 2007 | 11:06 PM
So Cal So Boosted's Avatar
Default Re: how old will a walbro 255 fuel pump last? (esedulerp5tenin)
What do you mean it cut out? If the fuel pump were to cut out/loose power while driving the car would shut off.
Do you have a wideband hooked up? Maybe your plugs fouled after racing hard all day.
Old Sep 10, 2007 | 10:48 AM
Default Re: how old will a walbro 255 fuel pump last? (So Cal So Boosted)
nope, plugs are fine. i checked those first. hmm, i wonder what it is then.
Old Sep 10, 2007 | 11:20 AM
IN VTEC's Avatar
My 190lph got really loud and started leaning the motor out at WOT above 4000rpm and would lean misfire at higher rpm's tipping in to accelerate. This is normally aspirated.
Old Sep 10, 2007 | 11:27 AM
thewrai6th's Avatar
Default Re: how old will a walbro 255 fuel pump last? (IN VTEC)
I had a Walbro 255HP that lasted less than 1 month, it just took a crap on the freeway one day. I ended up pulling off the seat and banging on it until it spun up again. I replaced it with the exact same model and I still have it.
Sounds like you are having other problems. Find someone with a wideband, at least.
Old Sep 10, 2007 | 12:30 PM
blackeg's Avatar
Default Re: how old will a walbro 255 fuel pump last? (thewrai6th)
they will or at least should start to get real loud when they are crapping out.
im on my 2nd car, 4th or 5th motor and a solid 50k miles with the same pump no problems at all
Old Sep 10, 2007 | 02:24 PM
Default Re: how old will a walbro 255 fuel pump last? (blackeg)
i have a wideband and its leaning out which is why i have narrowed down to the fuel pump
Old Sep 10, 2007 | 02:43 PM
eddie_ek's Avatar
My walbro 255 GSS-340 went for 2 1/2 years and about 3k miles boosted not a daily driver then went out on the hy way , had to pull over and let it cool so it can start, But that was probably my fault cause I only kept 2 to 4 gallons of fuel in the tank all the time.
Old Sep 10, 2007 | 05:10 PM
blackeg's Avatar
Default Re: how old will a walbro 255 fuel pump last? (eddie_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie_ek &raquo;</TD></TR><TR><TD CLASS="quote"> only kept 2 to 4 gallons of fuel in the tank all the time.</TD></TR></TABLE>
that will definately cause premature failure. happend to a friend of mine with only a few thousand miles tops. he used to run the tank dry or well below 1/4 and it crapped out one day. ive only taken mine below 1/8 once or twice, and try to keep it at least 1/4. having the pump submerged in gas in the tank helps to dissipate the heat and keep it cool and from overheating
Matt2458
Mar 30, 2010 10:45 AM
Jimster480
17
Oct 27, 2009 06:57 AM
classdork987654
Jan 1, 2009 01:16 AM
shermanyang
Mar 18, 2004 10:47 PM
typer694
Jun 19, 2001 06:57 AM
