engine wont run right
Old Sep 9, 2007 | 07:21 PM
EGKREW's Avatar
Default B20 vtec engine wont run right
i have a B20vtec engine and it turns on but when i give it gas it it will only go to 3000rpm. and it wont go higher it just bogs. could it be my ecu not feeding the fuel right to the engine?
Modified by EGKREW at 9:23 PM 9/9/2007
Old Sep 9, 2007 | 07:39 PM
crazyguy's Avatar
Default Re: engine wont run right (EGKREW)
are u using right ecu? do u have any CEL ?
Old Sep 9, 2007 | 07:50 PM
EGKREW's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">are u using right ecu? do u have any CEL ?</TD></TR></TABLE>
its a p28 ya pmd you
Old Sep 9, 2007 | 08:29 PM
EGKREW's Avatar
help!
Old Sep 10, 2007 | 07:14 AM
Kegan's Avatar
Your ECU is in safe mode. Check your distributor and make sure everything is straight with it. Are you throwing any CELs?
Old Sep 10, 2007 | 07:15 AM
crazyguy's Avatar
Default Re: (Kegan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kegan &raquo;</TD></TR><TR><TD CLASS="quote">Your ECU is in safe mode. Check your distributor and make sure everything is straight with it. Are you throwing any CELs?</TD></TR></TABLE>
+1
Old Sep 10, 2007 | 08:04 AM
EGKREW's Avatar
Default Re: (Kegan)
ya everthing is straight with the dizzy. it is wired up right.i just bought it from ylm.
Old Sep 10, 2007 | 08:11 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (EGKREW)
Is the check engine light on and, if so, what is the code?
Old Sep 10, 2007 | 08:15 AM
EGKREW's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Is the check engine light on and, if so, what is the code?</TD></TR></TABLE>
ya the cheak engine is on!. what code?
Old Sep 10, 2007 | 08:25 AM
91hybridDX's Avatar
Lookie here!
https://honda-tech.com/zerothread/1901557
Old Sep 10, 2007 | 08:39 AM
EGKREW's Avatar
Default Re: (91hybridDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hybridDX &raquo;</TD></TR><TR><TD CLASS="quote">Lookie here!
https://honda-tech.com/zerothread/1901557</TD></TR></TABLE>
checking
Old Sep 10, 2007 | 08:46 AM
EGKREW's Avatar
i get 6 short ones
Old Sep 10, 2007 | 09:11 AM
deerman2701's Avatar
Check the ect?
Old Sep 10, 2007 | 09:19 AM
EGKREW's Avatar
Default Re: (deerman2701)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deerman2701 &raquo;</TD></TR><TR><TD CLASS="quote">Check the ect?</TD></TR></TABLE>
that one thing will make the hole car not run right????
Old Sep 10, 2007 | 10:10 AM
Kegan's Avatar
Thats weird, I 've never seen the water temp sensor jack up a car that much. Unplug that particular sensor, plug it back in, reset the ECU and see what happens.
Old Sep 10, 2007 | 10:24 AM
Unceasing Measure
Default Re: (Kegan)
The coolant temperature sensor being fucked up can ruin all kinds of things, including the fuel tables and timing.
Old Sep 10, 2007 | 10:29 AM
EGKREW's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">The coolant temperature sensor being fucked up can ruin all kinds of things, including the fuel tables and timing.</TD></TR></TABLE>
so how can i fix that?
Old Sep 10, 2007 | 10:41 AM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGKREW &raquo;</TD></TR><TR><TD CLASS="quote">
so how can i fix that?</TD></TR></TABLE>
...replace the sensor
Old Sep 10, 2007 | 10:50 AM
EGKREW's Avatar
...replace the sensor </TD></TR></TABLE>
so all i do it cut a splice? that is the one under the vtec silonid. the grey on right not the white one
Modified by EGKREW at 12:46 PM 9/10/2007
Old Sep 10, 2007 | 12:16 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: B20 vtec engine wont run right (EGKREW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGKREW &raquo;</TD></TR><TR><TD CLASS="quote">i have a B20vtec engine and it turns on but when i give it gas it it will only go to 3000rpm. and it wont go higher it just bogs. could it be my ecu not feeding the fuel right to the engine?
Modified by EGKREW at 9:23 PM 9/9/2007</TD></TR></TABLE>
make sure that the VTEC and CTS plugs arent interchanged. Black plug = CTS
Green plug = VTEC.
Old Sep 10, 2007 | 12:17 PM
B serious's Avatar
Modified by EGKREW at 12:46 PM 9/10/2007</TD></TR></TABLE>
no. replacing the sensor means unscrewing the sensor from the head and putting in a new one. I think it's a 19mm socket?? 21?? ah whatever.
Old Sep 10, 2007 | 12:22 PM
EGKREW's Avatar
Default Re: (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
no. replacing the sensor means unscrewing the sensor from the head and putting in a new one. I think it's a 19mm socket?? 21?? ah whatever. </TD></TR></TABLE>
o ok thanks
Old Sep 10, 2007 | 12:42 PM
EGKREW's Avatar
Old Sep 10, 2007 | 01:01 PM
Ej Girl's Avatar
my friends car had that problem yesterday. since his ecu is out in the open someone must of made one of the connections to the ecu come out a little because after we plugged it in tight it worked perfectly fine. maybe thats not the problem but it wont hurt to check
gl fixing ur car
Old Sep 10, 2007 | 01:04 PM
EGKREW's Avatar
Default Re: B20 vtec engine wont run right (EjGirl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EjGirl &raquo;</TD></TR><TR><TD CLASS="quote">my friends car had that problem yesterday. since his ecu is out in the open someone must of made one of the connections to the ecu come out a little because after we plugged it in tight it worked perfectly fine. maybe thats not the problem but it wont hurt to check
gl fixing ur car</TD></TR></TABLE>
thanks for the advice but it is plunged in perfect.
