Just replace my VSS.
Old Sep 9, 2007 | 06:52 PM
civic91's Avatar
Default Just replaced my VSS.
Months ago I noticed that my speedometer is not reading correctly base on my rpm. Then today I finally replaced my VSS (base on research I did here) and still my speedometer is still off by at least 15mph (again this is base on my rpm). What do you think guys the problem? What else to check? I feel like I wasted my $150 for nothing. please help.
Modified by civic91 at 8:48 AM 9/10/2007
Old Sep 9, 2007 | 07:05 PM
g2daturbo's Avatar
Default Re: Just replace my VSS. (civic91)
what year car, what transmission and what size tires are on the car...let me know and ill get back to you with some ideas...
Old Sep 9, 2007 | 07:37 PM
civic91's Avatar
Default Re: Just replace my VSS. (g2daturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2daturbo &raquo;</TD></TR><TR><TD CLASS="quote">what year car, what transmission and what size tires are on the car...let me know and ill get back to you with some ideas...</TD></TR></TABLE>
It a 1995 GSR, tire is stock size.
Old Sep 10, 2007 | 04:02 AM
civic91's Avatar
Anybody have the same problem like mine? What's the fix? Need help
Old Sep 10, 2007 | 04:34 AM
Dogginator's Avatar
Daisy... Daisy...
Tire size will not affect the indicated speed in the cluster.
To the OP, have you verified that the tachometer is correct? Have the gauge needle been removed?
Old Sep 10, 2007 | 04:57 AM
civic91's Avatar
Default Re: Just replace my VSS. (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
To the OP, have you verified that the tachometer is correct? Have the gauge needle been removed?</TD></TR></TABLE>
Never touch the needle. This morning on the way to work, my rpm is around 2.5k (5th gear) and my speed is still 20mph. The speedometer needle is moving very slowly.
Old Sep 10, 2007 | 05:12 AM
Dogginator's Avatar
Daisy... Daisy...
You have a 91? Have you checked the cable connection in the cluster?
Old Sep 10, 2007 | 05:23 AM
civic91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">You have a 91? Have you checked the cable connection in the cluster?</TD></TR></TABLE>
I have a 1995 GSR. No, I haven't check the cable connection in the cluster. How do I check the cable in my cluster?
Old Sep 10, 2007 | 06:17 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic91 &raquo;</TD></TR><TR><TD CLASS="quote">
I have a 1995 GSR. No, I haven't check the cable connection in the cluster. How do I check the cable in my cluster? </TD></TR></TABLE>
You do not have a speedometer cable in a 1995 GSR. From your SN, I thought that you had a 91.
If you have another cluster, swap it to check the gauge operation.
Old Sep 10, 2007 | 06:20 AM
civic91's Avatar
If you have another cluster, swap it to check the gauge operation.</TD></TR></TABLE>
Is there any other way to check the gauge operation since I don't have another cluster!
Old Sep 10, 2007 | 08:42 AM
Dogginator's Avatar
Daisy... Daisy...
The Helm manual mentioned something about measuring the pulse frequency from the VSS. That isn't something the average multimeter can handle.
Old Sep 10, 2007 | 11:44 AM
civic91's Avatar
But I just put a brand new VSS.
Old Sep 10, 2007 | 11:55 AM
Dogginator's Avatar
Daisy... Daisy...
You could have a bad connection.
Old Sep 10, 2007 | 01:53 PM
g2daturbo's Avatar
check the pins in the connector my friend has a similar problem.. the terminals had corrodid away and had a bad connection.. with a new connector problem was solved!
Old May 3, 2009 | 10:55 AM
civic_driver's Avatar
I know this is an old thread but I had to correct something for anyone reading this.
Actually, that's not true. If you change the stock diameter of the rim+tire, the speedometer won't reflect the correct speed.
Rick hybrid
Dec 9, 2007 11:35 PM
jerm001
12
Apr 2, 2006 03:20 PM
aandrewcc
Mar 30, 2006 09:32 AM
shadowz64
Aug 15, 2005 04:17 AM
N1NjA TuRtLE
Sep 29, 2003 08:33 AM
