Anyone heard of DC's tearing at subframe? or is it more common with the civics?
Old Sep 9, 2007 | 05:35 PM
b18LS's Avatar
Default Anyone heard of DC's tearing at subframe? or is it more common with the civics?
I know this should most likely be in the suspension forum, but it seems to be moving slowly these days. Have any of you heard of an integra tearing at the subframe with a 22mm rear bar, or is it just the civics? Im considering the BSQ kit, and Im running a stock ITR suspension (not super stiff). The car will see some track time. Should I stick with stock GSR bars just to be safe?. (I dont want to run the larger braces) Thanks.
Old Sep 9, 2007 | 05:43 PM
alexisthemovie's Avatar
as long as you have reinforcement, it should be okay. i have only heard of ek civic subframes tearing with reinforcement.
Old Sep 9, 2007 | 05:55 PM
b18LS's Avatar
Default Re: (alexisthemovie)
Alright thanks man. That makes me feel better.
Old Sep 9, 2007 | 11:14 PM
doood's Avatar
been there done that
Default Re: (b18LS)
it can happen to dc's as well
http://www.honda-acura.net/for...arout
Old Sep 10, 2007 | 12:26 AM
BlueIntegraBoy's Avatar
Default Re: Anyone heard of DC's tearing at subframe? or is it more common with the civics? (b18LS)
https://honda-tech.com/zerothread?id=166668
Old Sep 10, 2007 | 03:16 AM
b18LS's Avatar
Default Re: Anyone heard of DC's tearing at subframe? or is it more common with the civics? (BlueIntegraBoy)
OUCH. I knew they were out there. Thanks guys you made the descision a lot easier
Old Sep 10, 2007 | 07:32 AM
SlammedDC2teg's Avatar
One of my friends rear sub frame mounts ripped off from running a thick bar. I know you need to reinforce a big to run the bigger sways but just in the rear.
Old Sep 10, 2007 | 07:54 AM
mrdeadman's Avatar
They let me pick
Just get a reinforcement kit and you'll be fine.
Old Sep 10, 2007 | 08:29 AM
iH8RICERZ's Avatar
Default Re: Anyone heard of DC's tearing at subframe? or is it more common with the civics? (mrdeadman)
I know its more likely to happen on the ek's.....mine tore a little bit on my DC2, but the damage was actually really minor compared to others and I was only using a 19mm neuspeed rear sway bar kit.
Here's what it looked like...
and this is what I did to fix it....(thanks to Redzone for the help)
I'd use the bsq kit or get the asr brace just to play things safe!
Old Sep 10, 2007 | 09:45 AM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
its common problem
Old Sep 10, 2007 | 10:39 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Anyone heard of DC's tearing at subframe? or is it more common with the civics? (iH8RICERZ)
I've been using an ITR 22mm bar with either BSQ or Beaks kit for over 4 years without a problem.
Old Sep 10, 2007 | 12:07 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
that's really wierd. you've basically got a stock ITR setup. Why the hell would it tear the subframe out? I think those other guys may have been running thicker/stiffer bars than the ITR. Or maybe they were running them on a very stiff setting (adjustable links). I've never heard of stock ITRs tearing out subframe links.
Old Sep 10, 2007 | 12:10 PM
mrdeadman's Avatar
They let me pick
Default Re: Anyone heard of DC's tearing at subframe? or is it more common with the civics? (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">that's really wierd. you've basically got a stock ITR setup. Why the hell would it tear the subframe out? I think those other guys may have been running thicker/stiffer bars than the ITR. Or maybe they were running them on a very stiff setting (adjustable links). I've never heard of stock ITRs tearing out subframe links. </TD></TR></TABLE>
The ITR's have a beefier subframe.
Old Sep 10, 2007 | 01:03 PM
Community Builder
If you mount an ITR bar to the stock GS-R swaybar mounts (which puts the bar out away from the subframe), then yes, it will most definitely tear the subframe over time.
ITR's have their bar mounted directly on the subframe, which is thicker than a GS-R subframe. So you likewise you have to mount the bar in a similar fashion, directly on the subframe with something to beef up the mount points (BSQ or Beaks is perfectly adequate, or ASR).
madmanmaigret
Jul 5, 2006 07:39 AM
NTGR8D
Mar 7, 2005 09:17 PM
Necessity
Suspension & Brakes
41
Jan 6, 2005 05:24 AM
silverb18
May 22, 2004 11:20 PM
tan2
Nov 18, 2003 02:33 PM
