Brake Pad squeal lube
Old Sep 9, 2007 | 05:03 PM
DxtoEm1's Avatar
Default Brake Pad squeal lube
Do i apply it on the back of the pads or inbetween the thin shin and the pad.. or both?
Doing it now.. please reply quickly
Old Sep 9, 2007 | 05:12 PM
BlueIntegraBoy's Avatar
Default Re: Brake Pad squeal lube (DxtoEm1)
Between the back of the pad and piston of the caliper.
Old Sep 9, 2007 | 05:14 PM
DxtoEm1's Avatar
Default Re: Brake Pad squeal lube (BlueIntegraBoy)
cause the lube says apply on metal to metal contact.. isn't the shim and the brake pad metal to metal contact? .. i believe u.. just curious
Old Sep 9, 2007 | 05:17 PM
The piston and back of the pad are metal. You can put some on the shim if you like, can't hurt.
Old Sep 10, 2007 | 09:11 AM
themikewoo's Avatar
check the sliders too. maybe put some lube on them if they are dirty or dry
andylawcc
Dec 22, 2009 04:00 PM
h8ted ek
Aug 26, 2008 04:18 AM
OEMcivic
Dec 22, 2004 11:58 PM
DaKINE-Ek
May 22, 2004 02:40 PM
RCautoworks
Feb 15, 2003 10:42 PM
