Rust on the rear quarter panel, before and after...hood before and after as well...
Old Sep 9, 2007 | 03:10 PM
LS94tegra's Avatar
Default Rust on the rear quarter panel, before and after...hood before and after as well...
This is the rear quarter panel rust on one side of my car when I first bought it.
This is the clear coat on the hood fading
This is after I took the DA sander to it
I used rust dissolver gel...it worked pretty good
I sprayed some more rust treatment to stop the rust
this is after it's done, still have to bolt bumper back on
this is after all the clear was taken off the hood, then sprayed with primer
This is what you get for buying a car from up north, but it's still fun to mess around with, gives me something to do
Old Sep 9, 2007 | 03:54 PM
CubanLynx84's Avatar
Default Re: Rust on the rear quarter panel, before and after...hood before and after as well... (LS94tegra)
What did you use to fill the rear quarter. If you used body filler eventually it wiil crack. I have the same problem right now. I've thinking of using the rust dissolver just to stop the spread until I can get the car repainted. I aslo want to shave my moldings as well but i'm going to have them welded shut.
Old Sep 9, 2007 | 04:01 PM
LS94tegra's Avatar
Default Re: Rust on the rear quarter panel, before and after...hood before and after as well... (CubanLynx84
yeah i did use body filler, i probably should have used fiberglass, but yeah that rust dissolver gel works really well, for 5 bucks you can't go wrong
95teg_ls's Avatar
are you gonna get it professionally painted?? if you are i would highly recommend putting metal in there then fiberglass then bondo just to fill it out. you bondo is going to crack and its gonna be a waste of time and money after its painted
Old Sep 9, 2007 | 04:06 PM
LS94tegra's Avatar
i was gonna spray it myself, i don't have a welder and i am a limited budget to pay someone else to do it...i spent all my money and buying the car lol
Old Sep 9, 2007 | 04:09 PM
LS94tegra's Avatar
Old Sep 9, 2007 | 04:20 PM
95teg_ls's Avatar
there is something called cold welding, its kinda like a glue, search around and find about that. but if its bondo in there its gonna crack and look like ***, do it right or do it twice.
Old Sep 9, 2007 | 04:25 PM
LS94tegra's Avatar
is it like wet weld? how long til it usually starts to crack?
Old Sep 9, 2007 | 04:30 PM
95teg_ls's Avatar
im not sure how long it will last, depends on how harsh the winter is, but as long as you havent painted it yet i would recommend grinding it down and redoing it. metal, then fiberglass, then body filler just to smooth it out.
and make sure all that the rust is completely gone, if any is left then its just gonna rust again
Old Sep 9, 2007 | 05:20 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Like everyone said, bondo(body filler) isn't that great other then use on the surface.
I did the same spot on my car, except it took more out on the bottom,
refilling the spot with metal, and then welding is def the best way.
http://www.we-todd-did-racing....6.JPG
http://www.we-todd-did-racing....G.JPG
NazVil86
Texas -OK -LA (Sales)
Nov 15, 2009 10:38 AM
lude1888
Aug 19, 2007 09:45 AM
Tommy_Gunns
Oct 11, 2004 06:27 PM
JeremyL
Apr 1, 2004 06:24 AM
fivespeedintegra
Feb 23, 2003 07:19 PM
