Jdm ECU
Old Sep 9, 2007 | 07:31 AM
killakayfee's Avatar
Default Jdm ECU
I just swapped an JDM F22B DOHC into my 92 prelude. I am using the stock h23 ECU but I kinda want to get the F22 Ecu. Is it worth it? can I just chip my H23 ecu? what should I do.
Old Sep 9, 2007 | 07:33 AM
NirVTEC's Avatar
Default Re: Jdm ECU (killakayfee)
Take it to a dyno to see what things look like.......maybe a used safc?
Old Sep 9, 2007 | 03:47 PM
safc?
Old Sep 10, 2007 | 03:34 AM
InvaderTrax's Avatar
Using the F22B ECU will do two things. It'll lean it out (vs the H23 ECU) and it will delete the knock sensor you don't have. Or, you could get a chipped P75 ECU and just get it tuned to your specific setup
Old Sep 10, 2007 | 07:55 AM
NirVTEC's Avatar
Default Re: (killakayfee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killakayfee &raquo;</TD></TR><TR><TD CLASS="quote">safc?</TD></TR></TABLE>
APEXi Super Air Flow Convertor
so you can at least tune your air/fuel a bit..
Old Sep 10, 2007 | 09:28 PM
Default Re: (:=:NirVTEC:=:)
isnt the p75 for an integra?
Old Sep 11, 2007 | 06:28 AM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killakayfee &raquo;</TD></TR><TR><TD CLASS="quote">isnt the p75 for an integra?</TD></TR></TABLE>
Logical guess would be a DOHC NON-VTEC B series....not sure though.
Old Feb 9, 2010 | 09:45 AM
h22junky's Avatar
Default Re: Jdm ECU
does using the jdm ecu make that big a differance cuz i have a jdm f22 swap and i burn gas like crazy
Old Feb 13, 2010 | 02:27 AM
BLUBB2's Avatar
Default Re: Jdm ECU
f22b DOHC?
P39 is the correct ECU for that motor.
DLB1994
May 30, 2016 07:14 AM
oramac_eg
Dec 4, 2008 02:45 PM
Accord95_H23A1
Nov 23, 2005 07:17 AM
rabbit94ludes
Jan 10, 2005 08:18 PM
junlude19
Nov 2, 2004 03:45 PM
