Driving impressions: 11.1" brakes to 11.8" brakes
Old Sep 8, 2007 | 10:20 PM
BrakeExpert's Avatar
Default Driving impressions: 11.1" brakes to 11.8" brakes
t
Old Sep 8, 2007 | 10:23 PM
FalkenSiR's Avatar
Default Re: Driving impressions: 11.1" brakes to 11.8" brakes (BrakeExpert)
good **** like always
Old Sep 8, 2007 | 10:25 PM
coupeKID's Avatar
any pics of the rl calipers? how much does it weight?
Old Sep 8, 2007 | 10:28 PM
Default Re: Driving impressions: 11.1" brakes to 11.8" brakes (coupeKID)
The 99 RL calipers are about 17lbs loaded, so these are probably around 18lbs loaded. The rotor is 15lbs compared to the 14lb 11.1" rotor.
Old Sep 8, 2007 | 10:50 PM
broketuner-Sol_Si's Avatar
If I had 16s I'd be PMing tyou to make me an identical setup
Old Sep 9, 2007 | 08:42 AM
racer_X_123's Avatar
Default Re: Driving impressions: 11.1" brakes to 11.8" brakes (broketuner-Sol_Si)
This is totally amazing!
For an awsome OEM big brake upgrade
Old Sep 9, 2007 | 08:59 AM
suspendedHatch's Avatar
So are you advertising? You keep making these posts...
Going to a bigger size rotor just means more resistance to heat/fade. Unless you're driving down long grades all the time, I don't think it would ever matter on the street. And more clamping force... any more clamping force than what I have now would just mean locking up the tires.
What proportioning valve are you using? Which end locks up first?
I have a simple Integra brake swap, ss lines, 15/16 master cylinder, wilwood adjustable prop valve, metalmaster pads, ate super blue fluid, decent street summer tires. I don't believe that there is a better street setup. OEM parts, reliability, ease of finding parts, ease of installation, cheap, doesn't require bigger than 15 inch wheels, doesn't take forever to warm up to OT, extremely effective.
On my Integra I just replaced the front calipers with Wilwoods.
Old Sep 9, 2007 | 09:14 AM
built562's Avatar
Default Re: Driving impressions: 11.1" brakes to 11.8" brakes (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">So are you advertising? You keep making these posts...</TD></TR></TABLE>
thank you... many good points made. but until we see actual 60-0 measurements and PROVEN positive data, they just look nice
Old Sep 9, 2007 | 09:25 AM
gsxr1k05's Avatar
just read your post on the 11.1 to 11.8 brakes. i have a 95 civic dx and plan to do the rear disc swap when i return from iraq. i would love to upgrade the fronts, and would like information on what would be my best bang for the buck. i know the 01 rl calipers are expensive, and i would have to get a custom bracket from you. from seeing your posts, i have confidence in your custom brackets, i just need a parts list comparision to figure out what would be the best options for me. thank you
Old Sep 9, 2007 | 09:35 AM
t
Old Sep 9, 2007 | 10:06 AM
gsxr1k05's Avatar
what year ex knuckles? and for the rl brackets, can i ger those from you milled? also 99-04 rl calipers? i was planning on going with the 1 inch master cylinder and booster with 4040 from the integra. i ran that on my crx and loved it,
Old Sep 9, 2007 | 10:48 AM
Brewer's Avatar
Default Re: (gsxr1k05)
Nice setup, nothing feels better than good brakes
Old Sep 9, 2007 | 11:08 AM
98greensi's Avatar
what size of rim car u run??, can u fit 15's on??? will be selling these kits?
Old Sep 9, 2007 | 11:36 AM
gsxr1k05's Avatar
Default Re: Driving impressions: 11.1" brakes to 11.8" brakes (98greensi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98greensi &raquo;</TD></TR><TR><TD CLASS="quote">what size of rim car u run??, can u fit 15's on??? will be selling these kits?</TD></TR></TABLE>
read the op and find your answer.
Old Sep 11, 2007 | 11:35 AM
roastbeefrichie's Avatar
Default Re: Driving impressions: 11.1" brakes to 11.8" brakes (FalkenSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FalkenSiR &raquo;</TD></TR><TR><TD CLASS="quote">good **** like always </TD></TR></TABLE>
Old Sep 11, 2007 | 07:24 PM
Default Re: Driving impressions: 11.1" brakes to 11.8" brakes (roastbeefrichie)
amazing
Old Sep 11, 2007 | 07:55 PM
MugenManR's Avatar
your at it again, keep the good work bro.
Old Oct 1, 2007 | 07:43 AM
t
Old Mar 12, 2008 | 08:18 AM
t
Old Aug 13, 2008 | 06:16 PM
Ivanek00's Avatar
how much for this setup
Front 11.8" rotor, 01 Acura RL milled brackets, 01 RL pads, NSX caliper bodies (91 spec.)
Rear 10.2" rotor, ITR rear brackets, calipers, and pads.
On Dx Front Kunckles and 2000 civic rear disc conversion
Damanzi
Suspension & Brakes
Jan 18, 2012 07:53 PM
JDMPR
Jul 18, 2009 02:09 PM
seeareex
Mar 3, 2008 01:06 PM
89dxhunchback
11
Jan 9, 2005 09:55 AM
