Failed Emissions in NJ, High NOX
Old Sep 8, 2007 | 06:03 PM
myrrh81's Avatar
Default Failed Emissions in NJ, High NOX
I was wondering if anyone had any suggestions besides the usual. I have a 95 Civic DX with an JDM OBD1 B16. HC CO was fine but NOX was 1522, when passing is 1372. I use the O2 sensor from the engine, converter from the DX, stock intake and exhaust. My timing may be off a bit. My old EVAP System had a port on the DX manifold which doesn't exist on the B16 so I never hooked up the EVAP. Could that cause high nox? Well, If anyone knows something about this I would appreciate some advice. Thanks
Old Sep 8, 2007 | 07:01 PM
myrrh81's Avatar
I forgot, my old engine blew a head gasket and there was a lot of water in the exhaust. I think this might have damaged the converter.
Old Sep 8, 2007 | 07:02 PM
97civicdx's Avatar
Default Re: Failed Emissions in NJ, High NOX (myrrh81)
What ecu u using, hopefully not the jdm one
Old Sep 8, 2007 | 07:06 PM
myrrh81's Avatar
The P30. It came with the engine so I'm sure it's the original JDM ECU. Are the USDM ECU'S different?
Old Sep 8, 2007 | 07:07 PM
95sloweg's Avatar
Default Re: (myrrh81)
usdm and jdm are diff ecu's
Old Sep 8, 2007 | 07:10 PM
myrrh81's Avatar
why the ecu cause only slightly high nox levels?
Old Sep 9, 2007 | 06:31 AM
myrrh81's Avatar
I guess no one has experience in this area. I know this is a difficult issue, Thank You anyway.
Old Sep 9, 2007 | 07:24 AM
gourley's Avatar
Just retard your timing (move the dizzy twords the front of the car) and goto inspection. Your car will run like **** for the time but it will lower your nox alot. Then get home and move the dizzy back to where it orgionally was. Use a timing light when moving the dizzy back for the correct timing.
Old Oct 20, 2007 | 11:58 AM
jlsmi2's Avatar
Default 94 GSR Similar Problem
I have a 94 USDM GSR swap (b18c1) in my 92 hatch and just failed NJ emissions for high NOx.
I have the USDM p72 computer and have passed twice before.
I will adjust my timing, it was a little off, but i'm not sure if this will make that much of a difference. what are other solutions to lowering NOx? Please note that it passed in the other two categories, so ONLY NOx was high.
Thanks
Old Oct 20, 2007 | 01:43 PM
Ex-Eg-Driver's Avatar
did u try using HEET?
Old Oct 20, 2007 | 01:51 PM
thesmogman's Avatar
Well I will tell you that coolant will contaminate your O2 Sensor and Cat.
Set your timing 1 or 2 degrees before spec to lower nox.
Old Oct 20, 2007 | 09:29 PM
jlsmi2's Avatar
Default Re: (JayKayNidas)
What does HEET stand for?
How would COOLANT affect the o2 sensor/cat?
-- Plan to adjust timing, change the plugs, etc and oil but still not sure if it'll bring me down enough.
This may seem like a really simple question but how do the o2 sensor and catalytic converter affect the level of NOx? I thought they had more to do w/ the level of HC and CO...
Which is more likely o2 sensor or cat or just timing?
znoj
Engine Management and Tuning
Feb 21, 2011 11:00 AM
racebum
Jan 14, 2009 01:48 PM
SoyMilk
Mar 2, 2008 11:15 AM
newtuner
Nov 12, 2007 12:39 PM
HaNsElBaDaSs
Sep 25, 2006 04:30 PM
