b16a block..recyling best way to remove ductile iron sleeves?
Old Sep 8, 2007 | 05:25 PM
slow ej1's Avatar
Default b16a block..recyling best way to remove ductile iron sleeves?
dont have a machine shop, block has a huge hole in the side of it its trash. the recyling yard is going to charge me 50 to take the block as is or give me 10 bucks if i recyle it (no iron sleeves)
Old Sep 8, 2007 | 06:49 PM
beepy's Avatar
Default Re: b16a block..recyling best way to remove ductile iron sleeves? (slow ej1)
lol. Find a better junkyard. Charging you for something they are going to sell to someone else?
Old Sep 8, 2007 | 07:18 PM
808DB1's Avatar
brake em out with a big hammer , thats what i did
Old Sep 9, 2007 | 09:09 PM
HiProfile's Avatar
Default Re: (808DB1)
I guess thats a good idea for $40, but the place I dropped my d16 block off at gave me $17 for the 'irony aluminum" as they called it. $10 is sort of a rip-off for scrap aluminum.
Old Sep 9, 2007 | 09:50 PM
greasemonkee's Avatar
bfh + chisel + full face shield
Cast doesn't bring a whole lot these days, but if you're bored...
Old Sep 10, 2007 | 08:42 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: b16a block..recyling best way to remove ductile iron sleeves? (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">lol. Find a better junkyard. Charging you for something they are going to sell to someone else?</TD></TR></TABLE>
yeah really, my yard will give me 3.00 for every hundred for what they call "irony aluminum" thats what that is. slide hammer?
Old Sep 16, 2007 | 09:32 AM
95 integra's Avatar
Default Re: b16a block..recyling best way to remove ductile iron sleeves? (boostedcivicsir)
I got paid like $45 for 2 bare heads and a block w/ stock sleeves and mains (about 130lbs as I recall). Keep in mind that the mains (the ones cast into the block) are also steel if Im not mistaken. Basically when they melt the aluminum the steel wont melt, so its not like they dont split it out....they just dont want to pay for it.
Modified by 95 integra at 6:08 PM 9/16/2007
Old Sep 16, 2007 | 11:30 AM
RC000E's Avatar
Default Re: b16a block..recyling best way to remove ductile iron sleeves? (95 integra)
I have NEVER heard of a yard CHARGING to take a cast aluminum block just because of the sleeves......R I P O F F!!! Go somewhere else.
Old Sep 16, 2007 | 12:58 PM
LordAphotic's Avatar
Yeah bro... go somewhere else. thats rediculous.
Old Sep 16, 2007 | 06:22 PM
aarontrini85's Avatar
Default Re: (LordAphotic)
do what i do. fill a plastic bin with all your crap you dont want then stop by the junkyard when there closed and leave it in front of the gate lol i dont make **** off scraping it but they cant charge me either
Old Sep 16, 2007 | 06:36 PM
zc911's Avatar
Default Re: (aarontrini85)
LOL up here thats called "Dirty Aluminum" last time was .50/lb, they payed me
Old Sep 17, 2007 | 01:44 PM
TeamNextGenChris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aarontrini85 &raquo;</TD></TR><TR><TD CLASS="quote">do what i do. fill a plastic bin with all your crap you dont want then stop by the junkyard when there closed and leave it in front of the gate lol i dont make **** off scraping it but they cant charge me either</TD></TR></TABLE>
haha,that's what we do at work all the time.i've gone a couple times when they were actually open-went to the back gate,tipped the rollback bed up and dumped a ton of steel scrap.the whole time there's a guy yelling at me to weigh in first...i just blew the horn and drove off.at least they don't have to pay for it.
chris
Old Sep 20, 2007 | 06:07 PM
*Boostwerks*'s Avatar
lol, I've done that too. I also left old oil in front of a grease monkey because no one around me would take the oil without making me buy something. I'd rather have them take it, than throw it in the dumpster.
Old Sep 22, 2007 | 12:53 AM
xci_ed6's Avatar
Default Re: (Boostwerks.com)
20lb sledge hammer. I disassembled a cylinder head with one, and a mower, and 4spd trans with a bad input shaft bearing.
Old Sep 22, 2007 | 04:48 PM
MidShipCivic's Avatar
They should be paying you if your giving them metal. Here in FL I get like $40 bucks for taking in a broken vehicle sub frame, but this is a auto recyclers metal scrap yard I take it to.
Old Sep 27, 2007 | 01:13 PM
bambbrose's Avatar
I get 40 cents a lb for cast alluminum here. You gotta pull out all the iron and steel though. Just took a bunch of POS manis and a junk block down the other day and got $57
Old Sep 30, 2007 | 09:11 PM
typeR#1141's Avatar
60-80 cents here in MN. i use to do the same thing but it takes too much efforts... easy money for jobless folks though
Old Oct 7, 2007 | 01:06 PM
welfarepc's Avatar
so how do shops get sleves out?
Old Oct 7, 2007 | 01:44 PM
b20turbojason's Avatar
Default Re: (welfarepc)
machine shops get sleeves out with a CNC machine when they need to install aftermarket sleeves
Old Oct 8, 2007 | 05:26 PM
lambertincorp's Avatar
Default Re: (b20turbojason)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greasemonkee &raquo;</TD></TR><TR><TD CLASS="quote">bfh + chisel + full face shield
its still good
D_koschak
Sep 22, 2008 02:55 PM
DarkTeg94
18
May 16, 2006 07:30 PM
-JSpecEk*9-
11
Jan 26, 2006 06:00 PM
Blanket Jackson
Nov 11, 2005 09:42 AM
DOMKID
Feb 10, 2004 09:34 PM
