Oil Pressure Gauge Question/problem
Old Sep 8, 2007 | 04:26 PM
SLPN H's Avatar
Default Oil Pressure Gauge Question/problem
Bought a Autometer Electric Oil Pressure gauge and hooked it up to my h22 civic. Ran the wires right, grounded it right and so on.
-Wire from sending unit to gauge
-Wire from cd player power to gauge
-Wire from ground to gauge
-Used teflon tape on the brass fitting for the sending unit
Now here's the question/problem:
-When I turn on the ignition....needle jumps up to 75 (0-100psi gauge)
-When I turn the car on and it idles...it shows no pressure
-When I start to give it gas the needle will move depending on how much gas i give it.
-If I floor it, the gauge goes up but doesnt pass 50. It will hit 50 and drop back down
-If Im crusing at ANY speed it shows no pressure at all
So did I do anything wrong or do I maybe have a bad sending unit?
And YES I have oil in the motor. Just changed the oil 2 days ago.
If I can I will take a vid of it and post it on here later tonight.
Old Sep 9, 2007 | 06:57 PM
SLPN H's Avatar
Default Re: Oil Pressure Gauge Question/problem (SLPN H)
Nevemind....exchanged the gauge and sensor...works now. Thanks for looking and helping.
Old Sep 9, 2007 | 07:16 PM
nighttrain33's Avatar
You shoud just switch to a mech. gauge. It was so easy to hook up and there is so much less to go wrong. It's also more accurate. I know this doesn't help now but it's a thought.
-Shane
LoseRPunKx182
Mar 22, 2006 04:26 AM
Si Shane
Oct 20, 2005 02:47 PM
SRCivic97
Nov 13, 2004 04:01 PM
Nextelbuddy
Aug 25, 2003 07:05 PM
