Sealing spoiler
Old Sep 8, 2007 | 04:02 PM
Xathine's Avatar
Default Sealing spoiler
I mounted my spoiler today, bought some rubber gasket material to keep water from getting in, but its too think and I can't bolt it down all the way.
Any ideas on what to use to seal the holes I drilled from water so it doesn't rust up my trunk?
Old Sep 8, 2007 | 04:03 PM
pdiggitydogg's Avatar
Whats wrong with a bead of clear silicone/rtv?
(the kind that requires solvent to wash off)
Old Sep 8, 2007 | 04:25 PM
Xathine's Avatar
Default Re: (pdiggitydogg)
Been told you can't put it on the paint
Old Sep 8, 2007 | 04:31 PM
says who? works fine on my trunk lid....
Old Sep 8, 2007 | 05:04 PM
Solster's Avatar
honda uses windshield adhesive sealent. on there stock wings.
and silicone as a body sealer is GETTO.
i worked in a body shop and your better off useing Seam sealer then silicone
Old Sep 8, 2007 | 05:10 PM
You can remove silicone... Its a bit tougher to remove window-weld/urethane.
Ghetto or not it works fine for me...and has for years
Old Sep 8, 2007 | 07:01 PM
Xathine's Avatar
Thanks for the input - I'll look into some of these ideas tomorrow.
Anyone else have any other ideas?
Thanks.
Old Sep 8, 2007 | 09:03 PM
NOFX's Avatar
H-T White Ops
My stock spoiler doesn't have any type of sealer on it that I can see. It has foam gaskets though.
Old Sep 8, 2007 | 09:06 PM
burnitdown's Avatar
you can get that foam at the hobby store and cut it to shape
Old Sep 9, 2007 | 06:37 AM
Xathine's Avatar
Default Re: (burnitdown)
Yeah, I tried, the smallest stuff I could get though was too thick, couldn't get the spoiler bolted down enough
Yuyodrift91
Paint and Body
Jun 15, 2009 05:26 PM
cilvia
Paint and Body
Aug 31, 2007 08:03 AM
cloudx71
Mar 27, 2005 09:15 PM
lilbastrd
Honda S2000
57
Mar 8, 2005 09:16 PM
munscher
Mar 8, 2004 07:19 AM
