F/S: B18c (sir-g) swap - minus transmission
Old Sep 8, 2007 | 11:25 AM
g3integragsr's Avatar
* B A N N E D *
Default F/S: B18c (sir-g) swap - minus transmission
LOWERED PRICE.....$1,300
I have a B18c motor I just pulled out of an integra im parting out. It doesn't include the transmission, Im using that for my car. I was told when I bought it that the motor has 80k on it. It does smoke a bit in vtec.
I did a compression test before pulling it and here are the numbers:
4 3 2 1
dry: 268 262 242 270
Wet: 300+ 300+ 300+ 300+
The compression tester that I used stopped at 300 psi. after just 4 cranks on each cylinder the compression tester maxed out.
This motor came in 1994 and 1995 Jdm Sir-g's. It is obd1 and has a chipped ecu. I don't know who it's chipped by but it has a guys name written on the outside of it.
These motors came with a stock 176 horsepower and 10.6:1 compression ratio.
Now for the pictures:
The swap includes most everything with it except:
Tranny
clutch
Flywheel
Powersteering pump
Crank pulley
and Spark plug wires.
The asking price for this motor is $1,300
Im located about 30 miles West of Saint Louis
Modified by g3integragsr at 8:50 PM 9/13/2007
Old Sep 9, 2007 | 11:06 AM
* B A N N E D *
bump
Old Sep 10, 2007 | 01:16 PM
* B A N N E D *
bump again
Old Sep 12, 2007 | 09:11 PM
* B A N N E D *
bumpty
Old Sep 13, 2007 | 07:49 PM
* B A N N E D *
$1,300 is the lowest I will take for it
Old Sep 14, 2007 | 02:05 PM
* B A N N E D *
motor runs perfect
Old Sep 14, 2007 | 02:33 PM
Fibercation's Avatar
Bump 4 ya...i also have some gsr trannys
Old Sep 15, 2007 | 09:15 AM
* B A N N E D *
Default Re: (Fibercation)
thank you sir
Old Sep 15, 2007 | 01:06 PM
* B A N N E D *
bump
Old Sep 16, 2007 | 12:06 PM
* B A N N E D *
bump again
Old Sep 16, 2007 | 04:30 PM
* B A N N E D *
bumpty
Old Sep 16, 2007 | 06:48 PM
* B A N N E D *
I know someone needs this for a swap
Old Sep 17, 2007 | 11:51 AM
* B A N N E D *
Old Sep 17, 2007 | 08:22 PM
* B A N N E D *
bump
Old Sep 18, 2007 | 01:20 PM
* B A N N E D *
Old Sep 18, 2007 | 09:47 PM
* B A N N E D *
bump
g3integragsr
Oct 28, 2007 03:24 PM
spooncivic28
10
Dec 19, 2005 11:58 AM
Cyber ITR
Jun 27, 2002 06:00 PM
