fuel cut on car help
my car has been driving fine lately but now when i drive it hard sometimes, at high rpms the fuel cuts off and the car boggs hard. it happen to me just the other day at 7k rpm in 3rd gear. if i keep on the gas, the car will then get fuel again and go.
any ideas?
any ideas?
um try changing your fuel filter and spark plugs. I'd imagine your injectors and pump are fine. If the first two don't work I would suggest you borrow someones Distributor and see if thats not the issue...happened to me before. Let us know.
i havent checked my oil level or anything yet. my injectors should be fine because they have been in for about 3k at the most. they are 550 injectors. yeah ill check my plugs and oil level when i can. im at work. thanks for the advice. any other suggestions i can check on when i get to my house?
