should i be worried?
Old Sep 8, 2007 | 02:07 AM
SLO Sol's Avatar
Default should i be worried?
im looking at buying a block its been sitting for a year the outer cylinder walls are looking a little rusty. id plan on building the motor and dropping it in im just worried about the time it has sat
Old Sep 8, 2007 | 05:07 AM
RyanA's Avatar
Default Re: should i be worried? (D-money 92si)
Well, I'd take some PB Blaster or WD40 with you. Spray it on and wipe it with a cloth. If the rust wipes off almost completely where you can see the shiny cylinder wall, you should be OK. IF the rust stays there, the block will probably have to be bored as a hone will probably make it too large to use that size piston again.
Old Sep 8, 2007 | 06:44 AM
b16a3delsol's Avatar
Default Re: should i be worried? (RyanA)
take it to a machine shop and let let them put it in the cooker and clean it up and it will be ok. they shouldnt charge you any more than 150 at the most and you know it will be clean.
Old Sep 8, 2007 | 08:56 AM
SLO Sol's Avatar
Default Re: should i be worried? (b16a3delsol)
it is the outer cylinder walls where the coolant flows
Old Sep 8, 2007 | 01:24 PM
SLO Sol's Avatar
anybody?
Old Sep 8, 2007 | 05:50 PM
RyanA's Avatar
If it's where the coolant flows (water jackets), I wouldn't be too worried. could be they just never flushed the coolant. If the actual cylinder walls are rusted, that's when you need to be cautious.
Ryan
famous323
Feb 10, 2012 01:31 PM
racerpat94
Dec 17, 2006 07:52 PM
JohnnyEF
May 29, 2003 12:38 PM
JohnnyEF
May 28, 2003 02:54 PM
Wicked Sol
May 11, 2002 04:36 PM
