codes 1 & 7??
im getting 2 CEL codes right now. it blinks once for a pretting long time then it blinks 7 times very quickly. ive read that the number 7 code is tps but what is the looong 1? is it the 02 sensor liek some threads state?? btw this is with an obd1 p72
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abram_quito »</TD></TR><TR><TD CLASS="quote">I LONG BEEP
IS INTAKE AIR TEMP SENSOR
IS MOUNT ON RIGHT SIDE PISTON #1 PIPE ON INTAKE MANIFOLD
MAKE SURE CONNECTED AND TEMP HAS A CIRCUIT
TEST W/ AN dvom : VOLTMETER
HOPE THIS HELPS</TD></TR></TABLE>awesome! any info on the quick 7 blinks?
7 quick blinks or flashes
is tp sensor throttle position
this means poor engine response to opening
throttle rapidly
or high idle speed
engine does not rev up when cold
eithered disconnected throttle angle sensor coupler
or open or short circuit in throttle angle sensor wire
or the worst faulty tps
hope this helps
throttle rapidly
or high idle speed
hope this helps
allicedout
Apr 2, 2007 12:28 PM
