Is this possible?
Old Sep 7, 2007 | 04:44 PM
Scotty2H's Avatar
Default Is this possible?
Sorry if it's been covered, search didn't turn up much.
I botched a downshift, 5 -> 3, missed the throttle so it had to catch up when I released the clutch from about 3000 rpm to 6500 rpm. Right after a CEL came on. Dealer said it was an over rev and it apparently said to 6200 rpm.
Can you mechanically over-rev the car to an RPM below the rev-limit of the car? Doesn't really make sense to me. I know what I did isn't good for the driveline, but how was it an over rev? was it just the rate of change of engine speed?
Thanks.
Old Sep 7, 2007 | 04:50 PM
JjuuN R's Avatar
Yes it's possible...
Old Sep 7, 2007 | 04:54 PM
Padawan's Avatar
Darth ModerVader
Default Re: (JjuuN R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">Yes it's possible...</TD></TR></TABLE>
Can you elaborate on this?
What he's describing sounds to me like he simply abruptly downshifted to 3rd gear, which can cause a some driveline shock, but wouldn't be what I'd refer to as an "over-rev".
What was the CEL actually indicating?
Old Sep 7, 2007 | 04:55 PM
Scotty2H's Avatar
How much damage can this do?
I've driven the car probably 15000 km since, but never got around to asking the question. Car runs as strong as ever.
Old Sep 7, 2007 | 04:58 PM
Scotty2H's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
What was the CEL actually indicating? </TD></TR></TABLE>
I never got the exact CEL number or description as I had just rushed in at the end of the dealers work day and asked them to read and clear it.
The tech said "over rev to 6200 rpm." I said "How's that possible, my rev limit is over 8000 rpm" then he shrugged and said "are you sure it's that high?", so naturally I just left.
Old Sep 7, 2007 | 04:59 PM
Padawan's Avatar
Darth ModerVader
Default Re: (Scotty2H)
Unless you physically broke something in the driveline, it shouldn't have caused any problems.
Old Sep 7, 2007 | 05:08 PM
JjuuN R's Avatar
Well he missed the rev match, so the RPMS were probably pretty low, it's pretty much just the motor going into "shock I guess"... going back up to 6200 against it's will for better terms of words... If you don't here any abnormal noises or notice any changes in performance they you're probably be alright...
Old Sep 8, 2007 | 07:34 AM
itr1244's Avatar
should be fine.. go reset the ecu and see if the ecl is still on
Old Sep 8, 2007 | 07:36 AM
GO-FIGHT-KILL's Avatar
If it's running, and correctly, you're lucky.
A friend of mine went from top of fourth, back into third in his DSM... The results weren't pretty. I have some pictures somewhere, I'll find them.
Old Sep 8, 2007 | 11:20 AM
Scotty2H's Avatar
Default Re: (GO-FIGHT-KILL)
Well thanks guys. I'm not too worried about it, car runs fine, I was just curious about what had happened.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">If it's running, and correctly, you're lucky.
A friend of mine went from top of fourth, back into third in his DSM... The results weren't pretty. I have some pictures somewhere, I'll find them.</TD></TR></TABLE>
You can definitely do some damage by missing a shift. What you friend did, however, is totally different than what I did.
Old Sep 8, 2007 | 12:31 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scotty2H &raquo;</TD></TR><TR><TD CLASS="quote">You can definitely do some damage by missing a shift. What you friend did, however, is totally different than what I did. </TD></TR></TABLE>
Exactly. That was an over-rev situation, while yours was not.
Old Sep 8, 2007 | 07:17 PM
#1151's Avatar
Maybe the timing belt slipped? How is it running right now?
Old Sep 8, 2007 | 07:43 PM
Ford Prefect's Avatar
Default Re: (#1151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by #1151 &raquo;</TD></TR><TR><TD CLASS="quote">How is it running right now?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scotty2H &raquo;</TD></TR><TR><TD CLASS="quote">I'm not too worried about it, car runs fine</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scotty2H &raquo;</TD></TR><TR><TD CLASS="quote">Car runs as strong as ever.</TD></TR></TABLE>
Old Sep 8, 2007 | 07:52 PM
pvt_awol's Avatar
Default Re: (Ford Prefect)
not really on topic, but I've mechanically over-revved a Honda engine, and the motor was and still is fine. (went from 5th and missed 4th, and put it in 2nd, DOH!)
I've also seen one over-revved with nitrous that didn't come out fine. The guy that did that one knew right away though.
I'm with the others, I think you are quite alright. As long as the car is running good still.
Old Sep 9, 2007 | 03:47 PM
#1151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ford Prefect &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys I think im turning gay dude </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by #1151 &raquo;</TD></TR><TR><TD CLASS="quote"> REALLY?? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ford Prefect &raquo;</TD></TR><TR><TD CLASS="quote">Yea man I saw Will Farrel take his shirt off in blades of glory and i almost creamed myself...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by #1151 &raquo;</TD></TR><TR><TD CLASS="quote">Thats some messed up stuff dude, if I were you I wouldn;t be saying that for everyone to see bro </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ford Prefect &raquo;</TD></TR><TR><TD CLASS="quote">It's ok I love the attention I get from the big strong muscley Gear heads in here... "we work hard and we play hard" </TD></TR></TABLE>
Old Sep 9, 2007 | 05:03 PM
Default Re: (#1151)
Wow, touchy are we? I point out that your question had already been answered by the OP, twice, and you feel the need to try to disparage me?
You are the one that made yourself look silly, I only pointed it out to you. It's a small man who needs to denigrate others to make up for their own mistakes.
Dude, grow up.
Old Sep 9, 2007 | 05:16 PM
totsie7944's Avatar
Reset the ECU, sounds like your fine.
Old Sep 10, 2007 | 02:44 PM
#1151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ford Prefect &raquo;</TD></TR><TR><TD CLASS="quote">Wow, touchy are we? I point out that your question had already been answered by the OP, twice, and you feel the need to try to disparage me?
Dude, grow up.</TD></TR></TABLE> omg man it was seriously a joke dude... I mean I wasn't trying to offend you in any way man, I do that all the time just to mess around!! Blah ohh well, im sorry if I hurt your feelers!
Razr2
15
Jan 1, 2008 10:24 PM
halfcard
May 4, 2007 07:02 PM
accord03coupe
Honda S2000
17
Mar 27, 2007 03:28 PM
bseries_beast
Dec 30, 2004 02:15 PM
projectej8
26
Jul 3, 2004 09:31 AM
