Just broke my motor mount......
Old Jun 15, 2002 | 09:53 PM
ImportHatch's Avatar
Default Just broke my motor mount......
heres the pic.....
The back pin is snapped off.
I was wondering if the piece that has the pins in it, that comes off the block. Can you unbolt that off of the block?? and if so, do I need to take the lower timing belt cover off. Or do you use new pins in that same piece. This just broke and havent had time to look at it considering its 11. Just wanted to get some info.
p.s. dont say anything about the purple hose, it came like that and am just too lazy to buy a new one....
Yager-
[Modified by ImportHatch, 10:54 PM 6/15/2002]
Old Jun 15, 2002 | 10:39 PM
TodaSi's Avatar
Default Re: Just broke my motor mount...... (ImportHatch)
Yes, you will have to remove the cover to get the bracket off, there are 3 bolts on it....so yea, it comes off.
Old Jun 15, 2002 | 10:43 PM
Default Re: Just broke my motor mount...... (TodaSi)
Thank you, I'm gonna do it tomorrow morning.
Yager-
Old Jun 16, 2002 | 06:02 AM
Chiovnidca's Avatar
If the bracket isn't bent you can just replace the studs. Be sure to use both studs and nuts are tight next time.
Old Jun 16, 2002 | 09:29 AM
gokooljapan's Avatar
Default Re: Just broke my motor mount...... (Chiovnidca)
sorry to see what happened...also you will have to remove the CRANK pulley to get that cover off....hth
Old Jun 16, 2002 | 10:16 AM
Default Re: Just broke my motor mount...... (gokooljapan)
Yeah i figured I was gonna have to take that off........Im about to run to my dads to get one of my mounts and try to do this today....
Yager-
slimbunnies
Jan 14, 2013 10:06 PM
CALI-HATCHIN310
Oct 1, 2011 05:20 PM
gabebauman
Jun 11, 2008 05:00 PM
invisible
Feb 11, 2007 05:50 PM
92civeg
Apr 10, 2004 10:14 PM
