need an alignment or wat???
Old Sep 7, 2007 | 02:25 PM
asergioc's Avatar
Default need an alignment or wat???
my inner tire is riding on metal what can i do???
heard something about a campering kit?
Old Sep 7, 2007 | 02:52 PM
b 1 6 a 2's Avatar
Sounds like you need a camber kit and an alignment afterwards, then new tires.
Old Sep 7, 2007 | 03:03 PM
pat92si's Avatar
Default Re: need an alignment or wat??? (asergioc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asergioc &raquo;</TD></TR><TR><TD CLASS="quote">my inner tire is riding on metal what can i do???
heard something about a campering kit?</TD></TR></TABLE>
Is your car lowered? if it is you might just need a camber kit and/or alignment to adjust the toe settings.
You could also have a bad bushing in your front end causing the wheel to ride at a different angle.
Old Sep 7, 2007 | 03:42 PM
Danronian's Avatar
If lowered, get a new tire, and get the toe set as close to zero as possible.
Most camber kits only cause problems. Camber helps a car with traction around corners and you can get an alignment so that your tires aren't eaten, and still be without camber kits.
spens 91 Ef
32
Apr 23, 2009 12:39 AM
zach1288
42
Nov 18, 2007 06:12 PM
EgRedSi
19
Dec 8, 2004 02:04 PM
CivicSwapper
Dec 11, 2003 06:53 AM
PorscheGT2
Dec 4, 2001 07:37 AM
