code 7 throttle angle
Old Sep 7, 2007 | 01:44 PM
k624ash's Avatar
Default code 7 throttle angle
I just swapped from and ls to gsr motor and moved my tps from the ls to the gsr. My voltages are .045 closed and 5.04 WOT. the check engine light only comes on if i keep the car full throttle for about 4 seconds. Why would it do this?
Old Sep 7, 2007 | 03:20 PM
k624ash's Avatar
Default Re: code 7 throttle angle (k624ash)
anyone?
Old Sep 9, 2007 | 05:47 PM
slowcivic2k's Avatar
Faulty TPS sensor, the signal should range from .45V closed to 4.5V WOT, having 5.04V at WOT indicates the arm inside the sensor is not touching the resistance tracks. If you hook up an OBD scan tool, your code should be one of these.
P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input
Old Sep 9, 2007 | 07:32 PM
k624ash's Avatar
Default Re: code 7 throttle angle (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">Faulty TPS sensor, the signal should range from .45V closed to 4.5V WOT, having 5.04V at WOT indicates the arm inside the sensor is not touching the resistance tracks. If you hook up an OBD scan tool, your code should be one of these.
alright thanks, im ordering a new one. My cars obd1, so i just read it with the paper clip and check engine light.
Thagoldenb
Jan 3, 2011 11:00 AM
T_bones
May 21, 2006 05:35 AM
Jaydeep
Aug 30, 2004 12:29 PM
igone916
Mar 3, 2003 08:59 PM
