Check timming w/ aftermarket pulley
Old Sep 7, 2007 | 09:34 AM
blue_hatch's Avatar
Default Check timming w/ aftermarket pulley
I bought a car with an aftermarket crankshft pulley... so how do I check timming now? Its for a y8
Old Sep 7, 2007 | 09:48 AM
forcefedferio's Avatar
Default Re: Check timming w/ aftermarket pulley (blue_hatch)
crank or cam pulley? if it's a crank pulley it should still have timing marks on it....if it's a cam pulley then there should also be markings for 0 degrees which would be base timing.
Old Sep 7, 2007 | 10:17 AM
pdiggitydogg's Avatar
if there are no markings, pull spark plug number one, drop in a long dowel, turn the crank until tdc.
Verify its 1 tdc with the dizzy rotor (pointing to contact 1) or cam markings O> <O
Old Sep 7, 2007 | 10:36 AM
blue_hatch's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcefedferio &raquo;</TD></TR><TR><TD CLASS="quote">crank or cam pulley? if it's a crank pulley it should still have timing marks on it....if it's a cam pulley then there should also be markings for 0 degrees which would be base timing.</TD></TR></TABLE>
its the crank pulley but has no markings on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">if there are no markings, pull spark plug number one, drop in a long dowel, turn the crank until tdc.
Verify its 1 tdc with the dizzy rotor (pointing to contact 1) or cam markings O&gt; &lt;O</TD></TR></TABLE>
thanks thats what i was looking for
Old Sep 7, 2007 | 10:38 AM
thesmogman's Avatar
Default Re: (blue_hatch)
They might have degree marks on the face of the pulley and just transfer it to the edge for timing purposes.
rogue420
Jul 20, 2008 06:55 PM
MenaceL.A.671
Sep 13, 2005 07:16 AM
civicek00
Jun 29, 2005 12:40 PM
spyderracing
14
Sep 26, 2004 09:10 AM
dpo95si
Aug 17, 2002 08:11 AM
