Quick clearance question for SFWD motor
Anyone in the forum have a roundabout measurement of a GSR main cap opening without bearings installed?
I believe I measured mine last night to be 2.450, which seems a bit big. I did it using a mic set to 2.3000 then a dial bore gauge zero'd out in the mic that read a +25 (25 x .0005) in the main bore.
Disregard, looks like I actually wound up measuring 2.3250 for the bore, 2.1650 on the journal, and hopefully .0790 for each ACL RACE bearing for a clearance of .002
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP »</TD></TR><TR><TD CLASS="quote">Disregard, looks like I actually wound up measuring 2.3250 for the bore, 2.1650 on the journal, and hopefully .0790 for each ACL RACE bearing for a clearance of .002
0.002?
i thought a thou and a half was pushing it.
please excuse my ignorance if i am wrong. he hee.
</TD></TR></TABLE>0.002?
i did not know that. never looked at oe specs. always went with my machinist told me a good clearance was. thats my lesson learned today.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">
0.002?
please excuse my ignorance if i am wrong. he hee.</TD></TR></TABLE>
you'd be suprised what some clearances are being run @.
0.002?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP »</TD></TR><TR><TD CLASS="quote">.0015 is OEM... I want to run a bit looser. </TD></TR></TABLE>
OEM Honda actually has a range. On a GSR engine, journals 1,2,4,5 are between .0009-.0017 and service limit is .002.
Journal 3 is .0012-.0019 and service limit is .0024
This gives a large window for OEM spec and work great for upgraded engines as well. Reason company's like ACL, Clevite and other manufactures can make a single size replacement bearing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP »</TD></TR><TR><TD CLASS="quote">Quite a few race motors are built w/ more than .003 clearance on the mains/rods.</TD></TR></TABLE>
Hondas?
Hondas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE »</TD></TR><TR><TD CLASS="quote">I run roughly .003 on the mains and .0025 rods</TD></TR></TABLE>
Do you mind if I ask what bearings you use to achieve this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx »</TD></TR><TR><TD CLASS="quote">
Do you mind if I ask what bearings you use to achieve this?</TD></TR></TABLE>
ACL Race HX and cut the crank down a little.
ACL Race HX and cut the crank down a little.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE »</TD></TR><TR><TD CLASS="quote">Pauter rods here. As for the retorque ....with the amount of boost, RPM's and power we make, we drop the pan after every race and check the main and Rod bearing anyways.</TD></TR></TABLE>
That explains it! lol
j/k man.
j/k man.
do you have to run thicker oil?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorRandy »</TD></TR><TR><TD CLASS="quote">
do you have to run thicker oil?</TD></TR></TABLE>
Of course
Of course
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com »</TD></TR><TR><TD CLASS="quote">
Of course </TD></TR></TABLE>
80-100 rear end oil?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro-motion »</TD></TR><TR><TD CLASS="quote">
80-100 rear end oil?</TD></TR></TABLE>
Please try that and get back to us on how it works for you
lol
lol
lol</TD></TR></TABLE>
so more like 20w50 right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF »</TD></TR><TR><TD CLASS="quote">PHDZINE
how many pulls/pass's are you getting out of it ? </TD></TR></TABLE>
Lots of dyno passes and 3 races on the same block and still going. Just need to make sure you have enough constant oil pressure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">
Hondas?</TD></TR></TABLE>
Yup, see above.
More N/A guys than anything else.
Yup, see above.
VWkila
May 7, 2005 12:20 PM
