VTEC KICKS IN AND STARTS TO CUT OFF
Old Sep 6, 2007 | 08:21 PM
92eghatchvx's Avatar
Default VTEC KICKS IN AND STARTS TO CUT OFF
I JUST WANT TO KNOW IF ANYBODY KNOWS WHATS WRONG WITH MY MOTOR IT DONT
HIT VTEC FOR 1stGEAR. HITs VTEC 2 GEAR LIKE A 7rpm AND 3rdGEAR HIT AT 4rpm BUT STARTS TO CUT OUT O ITS A 91 B16A IN A 92 EG HATCH VX
Modified by eddiemonreal at 11:21 PM 9/6/2007
Old Sep 6, 2007 | 08:25 PM
Syndacate's Avatar
Default Re: VTEC KICKS IN AND STARTS TO CUT OFF (eddiemonreal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddiemonreal &raquo;</TD></TR><TR><TD CLASS="quote">I JUST WANT TO KNOW IF ANYBODY KNOWS WHATS WRONG WITH MY MOTOR IT DONT
HIT VTEC FOR 1GEAR HIT VTEC 2GEAR LIKE A 7 AND 3GEAR HIT AT 4BUT STARTS TO CUT OUT O ITS A 91 B16A IN A 92 EG HATCH VX</TD></TR></TABLE>
Are you throwing a CEL?
Old Sep 6, 2007 | 08:32 PM
240sx1faster's Avatar
get a new car
Old Sep 6, 2007 | 08:41 PM
Frozen E's Avatar
H-T White Ops
I have no idea what your all cap writing *** is talking about.
::Edit::
I see you edited your post but it still makes no damn sense.
Modified by IslandSi at 11:05 PM 9/6/2007
Old Sep 6, 2007 | 09:33 PM
marshun's Avatar
what ecu you running? maybe you hit the speed gov.
Old Sep 6, 2007 | 09:48 PM
EM1SiR85's Avatar
From: everywhere., cali,nevada,new york., united states
Default Re: VTEC KICKS IN AND STARTS TO CUT OFF (marshun)
check oil pressure. vtec works out of oil pressure so start from there.
Old Sep 6, 2007 | 10:19 PM
i'am running a gsr computer obd1 it was running good before it just started to do it like 2 days ago
Old Sep 6, 2007 | 11:10 PM
numberone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1SiR85 &raquo;</TD></TR><TR><TD CLASS="quote">check oil pressure. vtec works out of oil pressure so start from there.</TD></TR></TABLE>
Old Sep 8, 2007 | 09:03 AM
ek9 citrus's Avatar
After you check your oil pressure might want to check your vtec wiring through your ecu make sure all the pins are fastened and secure some time they tend come loose.
Old Sep 8, 2007 | 09:06 AM
Syndacate's Avatar
Default Re: VTEC KICKS IN AND STARTS TO CUT OFF (ek9 citrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9 citrus &raquo;</TD></TR><TR><TD CLASS="quote">After you check your oil pressure might want to check your vtec wiring through your ecu make sure all the pins are fastened and secure some time they tend come loose.</TD></TR></TABLE>
There's no justification that VTEC works in every gear except 4th, electrically.
Old Sep 9, 2007 | 01:56 AM
EM1SiR85's Avatar
Default Re: VTEC KICKS IN AND STARTS TO CUT OFF (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
There's no justification that VTEC works in every gear except 4th, electrically.</TD></TR></TABLE>
??? lol lol lol lol!!! a comedian not a tech
Old Sep 9, 2007 | 02:00 AM
Default Re: VTEC KICKS IN AND STARTS TO CUT OFF (EM1SiR85)
got it fix thanks 4 the info
Old Sep 9, 2007 | 05:51 AM
jfruauff's Avatar
I assume low oil,lol. Get in the habit of checking your oil with every gas fill up,lol
Old Sep 9, 2007 | 12:47 PM
marshun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddiemonreal &raquo;</TD></TR><TR><TD CLASS="quote">got it fix thanks 4 the info </TD></TR></TABLE>
so what fixed it?
Old Sep 9, 2007 | 01:27 PM
my v-tec gasket screen was dirty and the oil was not getin to the solenoid
Old Sep 9, 2007 | 05:30 PM
nighttrain33's Avatar
Default Re: VTEC KICKS IN AND STARTS TO CUT OFF (92eghatchvx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eghatchvx &raquo;</TD></TR><TR><TD CLASS="quote">my v-tec gasket screen was dirty and the oil was not getin to the solenoid </TD></TR></TABLE>
I'd get a p30 if I were you. Your car will run a lot better. For whatever reason when I did my swap, the place I got all my stuff from gave me a p72. Switched out for a p30 and it is much better.
-Shane
Old Sep 10, 2007 | 05:12 PM
Default Re: VTEC KICKS IN AND STARTS TO CUT OFF (nighttrain33)
i hear that they make you idle hella high whit the p30 man
CodyC142
13
Apr 13, 2006 09:34 AM
jaypak
Apr 27, 2004 12:03 AM
DissidentCivic
30
Jan 14, 2004 03:59 PM
MugenHonda
12
Sep 25, 2003 03:22 PM
Built B16A
Apr 12, 2003 04:28 AM
