removing crank pulley
Old Sep 6, 2007 | 06:01 PM
royalfelix's Avatar
Default removing crank pulley
hey i have an h23a1 and im upgrading the crank pulley but when i tryed to take out the crank pulley it would just turn the motor.... how do i go about this....
Old Sep 6, 2007 | 06:22 PM
SteveoBA8's Avatar
Default Re: removing crank pulley (royalfelix)
Buy the Crank pulley holder tool. Work's great!
Old Sep 6, 2007 | 06:36 PM
saikou's Avatar
Yup.
Use 1/2 tools when you go to break the bolt loose.
Old Sep 6, 2007 | 07:21 PM
mgags7's Avatar
Default Re: (saikou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saikou &raquo;</TD></TR><TR><TD CLASS="quote">Yup.
Use 3/4" tools when you go to break the bolt loose. </TD></TR></TABLE>
fixed
Old Sep 6, 2007 | 07:29 PM
royalfelix's Avatar
can i buy this at the discount or w/e?
Old Sep 6, 2007 | 07:59 PM
esedulerp5tenin's Avatar
Default Re: (royalfelix)
http://www.amazon.com/Alltrade...r=8-1
works like a charm
Old Sep 7, 2007 | 05:29 AM
xxmastermindxx's Avatar
Default Re: (esedulerp5tenin)
^^ thats the tool i used for mine, and it popped off literally on 1st try. used a 10 foot piece of pipe as a breaker though
Old Sep 7, 2007 | 06:05 AM
Finest's Avatar
What's there to upgrade for the crank pulley?
Old Sep 7, 2007 | 07:00 AM
DR's Avatar
DR
Default Re: removing crank pulley (Finest)
The H22 Euro R doesn't have the power steering belt so its crank pulley is lighter. I wouldn't use aluminum crank pulleys as I've seen a lot of wear on the #4 main bearing on H22's that use them.
Old Sep 7, 2007 | 09:16 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">What's there to upgrade for the crank pulley?
Replace it with a belt-driven supercharger?
Old Sep 7, 2007 | 01:51 PM
royalfelix's Avatar
i have an h23a1 engine and i bought unorthodox set, crank p/s and alt. i drive my car alot do you think it will do damage to the motor really? is there any proof of this? i just finished rebuilding my engine and the crankshaft was all torn up the # 4 and 3 sleeves where the rod goes connected to. well either way im going to put it on and hope for the best i think ill take it to the machanic though... last QUESTION can i also remove it by sticking a flat head screwdriver in the flywheel to hold it in place? and is this nut reverse? or does it loosen lefty like it should?
alex14
13
Dec 10, 2010 09:28 AM
fe519
May 13, 2005 07:19 AM
duececoupe2
Feb 28, 2005 08:04 PM
airwalk07143
Jul 26, 2004 08:58 PM
TrueZen
Feb 27, 2004 07:42 AM
