Can someone help with installing a techometer in a 2004 civic?
I dont have a tach on my car and i need one. I have an idea on how to install it power wire ground ignition and distributor. someone please let me know if there is anything else and if they have any good suggestions. thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uneekvisions »</TD></TR><TR><TD CLASS="quote">I heard that doing that can fry your harness? Says my local dealer.
I would say your dealer doesn't really look into the wiring all that much. The wiring is the same gauge from EX to base model.
</TD></TR></TABLE>I would say your dealer doesn't really look into the wiring all that much. The wiring is the same gauge from EX to base model.
So if you don't have a tach? then you must have a VP, one option is to buy a lx, ex, cluster and plug it in, but expect you must run your tach wire to the harness, because the wire is located all the way behind you right headlight, also you might have to rewire certain wires because the ex cluster is lighted as soon as you start your engine, second option which might be a consider a little ricer, is to buy an aftermarket tach, check out my car domain where i did the second option, http://www.cardomain.com/ride/2415786/7. hope this helps
dude your awesome. yea i got a vp, was a good deal for me so i got it. but now im looking into add ons
im thinking about getting some more guages also, im gonna get a volt guage, and a couple others i havent decided on yet cause i wanna know everything going on with my car. Im a truck driver and have a million guages in my truck so im used to knowing whats going on. Hit me up and let me know from time to time what else you have done. perhaps we can help each other out with **** thanks again
VERYYYYYYYYY nice, im doing this as soon as possible. prolly put it somewhere else though. we'll see. but very nice write-up on cardomain.
for one i have an 03-05 civic lx cluster if u want it, but the wiring in a vp with no tachometer is different then an ex or lx with a tachometer, i have an 03 ex cluster in my 05 vp. i work at a Honda dealer and unless u have an ex cluster like i was luckier then hell to find off of a wrecked front clip u will have to re-pin most of the of he two connectors that are in the gauge cluster if u can find an ex harness you should just splice it in and then if anything you can use the stock cluster, the only thing i have had a problem with and have not had time to mess with is i have no reverse lights after the swap
Hey thanks man i appreciate it but i think ill just do what that other guy said and install and after market one. Sounds like a huge headache to repin and stuff. thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">
I would say your dealer doesn't really look into the wiring all that much. The wiring is the same gauge from EX to base model.</TD></TR></TABLE>
not true. any cluster from an 01-05 lx will work. if you get a cluster from an ex, you'll have to re-pin the clip...which there are plenty of diagrams and vids for.
i got my cluster for my 04 vp for $40 on ebay and its out of an 02 lx coupe. just make sure you get a manual cluster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwh245 »</TD></TR><TR><TD CLASS="quote">dude your awesome. yea i got a vp, was a good deal for me so i got it. but now im looking into add ons
im thinking about getting some more guages also, im gonna get a volt guage, and a couple others i havent decided on yet cause i wanna know everything going on with my car. Im a truck driver and have a million guages in my truck so im used to knowing whats going on. Hit me up and let me know from time to time what else you have done. perhaps we can help each other out with **** thanks again</TD></TR></TABLE>
Hey no problem, just keep in touch and i'll share stuff i have done and found, i try to update my cardomain for stuff i have done or researched, once your of the trial membership i'll send you my email, because i can't do it now since your still in trial
im thinking about getting some more guages also, im gonna get a volt guage, and a couple others i havent decided on yet cause i wanna know everything going on with my car. Im a truck driver and have a million guages in my truck so im used to knowing whats going on. Hit me up and let me know from time to time what else you have done. perhaps we can help each other out with **** thanks again</TD></TR></TABLE>Hey no problem, just keep in touch and i'll share stuff i have done and found, i try to update my cardomain for stuff i have done or researched, once your of the trial membership i'll send you my email, because i can't do it now since your still in trial
